Arduino Projects
Arduino Projects
Blog A simple DIY Oscilloscope with Arduino Uno and Mega
  • Date Created: 26 Dec 2014 11:05 AM Date Created
  • Views 40131 views
  • Likes 20 likes
  • Comments 79 comments
  • mega
  • ardbeginner
  • tft
  • oscilloscope
  • uno
e14 Contributor
e14 Contributor
26 Dec 2014
My DIY Oscilloscope, how i got my signal image
Content :
- Description
- Screenshots
- Video
- Credits and links
Descriptions
I am experimenting with RF and IR signals in various frequencies and had some trouble with the receivers and needed to see what kind of signal i was receiving.
I cannot afford a real oscilloscope but i knew about the older Arduino oscilloscopes.
After trying many different versions of code and tutorials, I was unable to get a single one to work, and all the tutorials and guides around was 2-3 years old.
Not sure if it is the IDE or the actual hardware that has changed in such a way that it didn't work anymore.
I finally found a working oscilloscope from a Japanese website, (linked below) and a working TFT screen library,
meaning i could read the various signals received.
Clearly the limitations are 0-5v but that is fine, what i needed to know is either wave type and frequency, and this is sufficient.
It also gives me an indication of the amplitude which is just a nice bonus.
But what I'm most happy with, is the two channel feature, i often use the second channel as a reference point to be able to
differentiate the main channel on the screen.
Some screenshots..
This is the .96" OLD test, single wave test imageimage
2.4" TFT screen on the Uno,    two right images same screen on a Mega.
A youTube vidoe i made on the experience.
Credits and Links :
My compilation of the Oscilloscope and TFT library  ( what you see on the video and images ) :
https://dl.dropboxusercontent.com/u/19761809/arduino/Vaupell-Oscilloscope.zip
Original Oscilloscope link (code by : Noriaki Mitsunaga ) :
http://n.mtng.org/ele/arduino/oscillo-j.html
Original TFT display link ( TFT shield library source ) :
http://www.smokeandwires.co.nz/blog/a-2-4-tft-touchscreen-shield-for-arduino/
TFT library :
Library : https://github.com/Smoke-And-Wires/TFT-Shield-Example-Code
    e14 Contributor over 11 years ago in reply to 4ringfan +2
    True, I highly recomened if using ribbon cable, buy a roll, and add the ends yourself, much much cheaper. I usually buy them home in 10 meters at a time. But, I try to use cable as little as possible,…
  • 4ringfan
    4ringfan over 11 years ago +1
    I just received a LCD TFT shield that I had ordered for no particular reason. Now I'm going to have to play with it. Thanks for the incentive!
    e14 Contributor over 11 years ago in reply to e14 Contributor +1
    Nope just one of them. The problem was the Screen it took up all my pins on the arduino uno. You could do a messy workaround, either by soldering something onto the SD pins (since were not using them anyway…
  • jc2048
    jc2048 over 10 years ago in reply to e14 Contributor
    The buttons work by changing the voltage that is read by input pin A3 on the Arduino.
    With no buttons pressed, the voltage at A3 is 4.69V.
    If you press SW10 (Menu) the voltage goes to 0V. [The switch connects the input to GND]
    If you press SW9 (CH1 range down) you have a potential divider with 100 ohms up to 5V and 10 ohms down to GND. The voltage = 10/(100+10) * 5, which is 0.45V
    If you press SW8 (CH2 range down) you have a potential divider with 100 ohms up to 5V and 20 ohms [10+10] down to GND. The voltage = 20/(100+20) * 5, which is 0.83V
    And so on.
    Here are all the voltages
    SW10 Menu              0
    SW9  CH1 range down    0.45
    SW8  CH2 range down    0.83
    SW7  TIME/Div (slow)   1.43
    SW6  TRIG_MODE         1.87
    SW5  Send              2.58
    SW4  TRIG_MODE         3.03
    SW3  TIME/Div (fast)   3.59
    SW2  CH2 range up      3.9
    SW1  Ch1 range up      4.26
    SW0  Start/Hold        4.56
    No button pressed      4.69
    I think I've calculated them correctly, but you might want to check them again.
    To test your circuit, put a meter on A3, press each button in turn and check that the voltage is close to the value above. There will be a bit of difference, because your resistors only have a certain tolerance, but it should be fairly close. If any are a long way out you might have a wrong value resistor or a bad connection.
    e14 Contributor over 10 years ago in reply to jc2048
    in Romania, the frequency of the mains is 50Hz and the voltage is 230Vac with an error of +-6%.
    Every time i measure it's between 227-230Vac.
    recycler66 i worked on it last evening, the buttons seem do do something..i did't figured it out yet, i need a pwm generator made wit an arduino probably, to really understand what do they do.
    Also when you press for example channel down it drops the signal to the 0(Gnd) but it doesn't change the values shown in the top right corner of the screen (volts/divission for example) when i press the volts/divission button.
    I'll figure it out(i hope) this weekend;))
    Cheers guys, i like this community.
  • jc2048
    Is the period of the sine wave the same as for the mains in your locality?
  • jc2048
    I'd say ohms [the potentiometer is labelled as being 10k].
    It gives about 3mA through the chain, which is reasonable, but when you press the Menu key it takes 50mA from the supply which is a bit high. You could try multiplying all the values by 10 - that would reduce the current draw whilst leaving all the voltage levels the same [so you wouldn't need to change the software]. Go too far, though, and you'll have problems with noise giving false detection of the switches (which might be the reason that they ended up with those values).
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Also the difference in waveform (supply vs usb cable) i fixed it last night...it's because some analog pin it's not correctly defined and used.
    Mihai Arald.
