Arduino Projects
Arduino Projects
Blog Arduino temperature logger which saves data on SD card and sends it to Ubidots IOT application
  • Author Author: dragonboliero
  • Date Created: 16 Dec 2015 2:34 PM Date Created
  • Views 4448 views
  • Comments 8 comments
  • logger
  • c
  • python
  • ardintermediate
  • temperature
  • ubidots
  • card
  • sd
dragonboliero
dragonboliero
16 Dec 2015
Hello,
Today I would like to share with you my second little project. Its an Arduino temperature logger which saves data on micro SD card and thanks to a short Python script it can also send data to Ubidots IOT application. The circuit itself is very simple, in order to complete it all you need is:
11 - jumper wires
1 - 4.7K ohm resistor
1 - DS18B20 temperature sensor
1 - SD card reader
1 - Arduino UNO
Here's the circuit's schematic:
Here's a video showing how assemble the circuit:
Arduino sketch for this project:
#include <OneWire.h> //library for communication with temperature sensor
#include <DallasTemperature.h> //temperature sensor library
#include <SD.h> //sd card reader library available in every Arduino IDE
#include <SPI.h> //library for communication with SD card reader
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
File logs;  // variable responsible for writing to file
float temp; //variable storing the current temperature
int number = 0; //variable holding the number indicating current entry in csv file
unsigned int hour = 20; //variable storing current hour
unsigned int minute = 45; //variable storing current minute
unsigned int day = 2; //variable storing current day of the week
unsigned int date = 15; //variable storing current day of the month
unsigned int month = 12; //variable storing current month
unsigned int year =  2015; //variable storing current year
unsigned int leap_year = 0; //variable for checking whether it's a leap year or not
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup(void)
  // start serial port
  Serial.begin(9600);
  SD.begin(10);
  // Start up the library
  sensors.begin();
} //end of void setup
void loop(void)
  //checking whether it's leap year or not
  if (year % 4 == 0)
  leap_year = 1;
  else
  leap_year = 0;
  //changing minutes
  if (minute < 55)
  minute +=5;
  else
  minute = 0;
  //changing hour
  if ((minute == 0) && (hour < 24))
  hour++;
  if ((minute == 0) && (hour == 24))
  hour = 0;
  //changing day of the week
  if((minute == 0) && (hour == 0) && (day <8))
  day +=1;
  if((minute == 0) && (hour == 0) && (day == 8))
  day = 1;
  //changing day of the month
  //formula for 30 day months
  if ((date < 31) && ( (month == 4) || (month == 6) || (month == 9) || (month == 11)) && (hour == 0) && (minute ==0))
   date++;
  if ((date == 31) && ( (month == 4) || (month == 6) || (month == 9) || (month == 11)) && (hour == 0) && (minute ==0))
   date = 0;
   month++;
  //formula for February
  if ( ((date < 29) && (month == 2) && (hour == 0) && (minute == 0) && (leap_year == 0)) || ((date < 30) && (month == 2) && (hour == 0) && (minute == 0) && (leap_year == 1)) )
   date = date +1;
  if ( (date == 29) && (month == 2) && (hour == 0) && (minute == 0) && (leap_year == 0) || ((date == 30) && (month == 2) && (hour == 0) && (minute == 0) && (leap_year == 1)) )
   date = 0;
   month = 3;
  //formula for 31 day months
  if ((date < 32) && ( (month == 1) || (month == 3) || (month ==5) || (month == 7) || (month == 8) || (month == 10) || (month == 12)) && (hour == 0) && (minute ==0))
    date++;
  if ((date == 32) && ( (month == 1) || (month == 3) || (month ==5) || (month == 7) || (month == 8) || (month == 10) || (month == 12)) && (hour == 0) && (minute ==0))
   date = 1;
   if(month <12)
   month++;
   else
   month = 1;
  //changing year
  if( (hour == 0) && (minute == 0) && (date == 1) && (month == 1))
  year++;
  sensors.requestTemperatures(); // Send the command to get temperatures
  temp =  sensors.getTempCByIndex(0); //assigning sensor's vale to the variable
  Serial.println(temp);
  logs = SD.open("logs.csv", FILE_WRITE); //assigning file to which we want to write the data
  if(logs) //if opening of the file was successful
   if (number == 0)
   logs.println("sep=,"); //we add this line to the file so that excel 2013 and newer software knows that this is coma separated file
   //then we write entry number, date and sensor read
   logs.print(number);
   logs.print(",");
   logs.print(temp); //finally we add temperature read from sensor
   logs.print(",");
   if (hour < 10)
   logs.print("0"); //we add 0 is hour is lower than 10
   logs.print(hour);
   logs.print(":");
   if(minute <10)
   logs.print("0"); //we add 0 if minute is lower than 10
   logs.print(minute);
   logs.print(" ");
   switch(day) //we add day of the week appropriately
    case 1:
     logs.print("Monday");
     break;
    case 2:
     logs.print("Tuesday");
     break;
    case 3:
     logs.print("Wednesday");
     break;
    case 4:
     logs.print("Thursday");
     break;
    case 5:
     logs.print("Friday");
     break;
    case 6:
     logs.print("Saturday");
     break;
    case 7:
     logs.print("Sunday");
     break;
   logs.print(" ");
   logs.print(date);
   logs.print(" ");
   switch(month)
    case 1:
     logs.print("January");
     break;
    case 2:
     logs.print("February");
     break;
    case 3:
     logs.print("March");
     break;
    case 4:
     logs.print("April");
     break;
    case 5:
     logs.print("May");
     break;
    case 6:
     logs.print("June");
     break;
    case 7:
     logs.print("July");
     break;
    case 8:
     logs.print("August");
     break;
    case 9:
     logs.print("September");
     break;
    case 10:
     logs.print("October");
     break;
    case 11:
     logs.print("November");
     break;
    case 12:
     logs.print("December");
     break;
   logs.print(" ");
   logs.println(year); //printing year to the file
   Serial.println("Saving successful");
   logs.close();//we close and save the file
  logs.flush();
  delay(300000); // we delay program for 5 minutes and then take another read
  //delay(60000); //for testing purposes 1 minute
  //delay(2000);//for testing purposes 2 seconds
  number = number + 1; // we add 1 to the entry counter
Python script which allows communication between Arduino and Ubidots application:
from ubidots import ApiClient #importing ubidots api
from time import * #importing standard time library
import serial #importing pyserial library
api = ApiClient ('your_account_key') #key of our ubidots account
ser = serial.Serial('COM6', 9600, timeout = 0) #establishing communication with Arduino serial port
temp_val = api.get_variable('your_variable_key') #ubidots variable's key with which we want to communicate
while True:
    current_temp = ser.readline(6) #reading first 6 characters from serial port
    if ( (current_temp[:1] == '-')or(current_temp[:1] == '1') or (current_temp[:1] == '2') or (current_temp[:1] == '3') or (current_temp[:1] == '4') or (current_temp[:1] == '5') or (current_temp[:1] == '6') or (current_temp[:1] == '7') or (current_temp[:1] == '8') or (current_temp[:1] == '9') ):
            float_current_temp = float(current_temp[:5]) #converting value read from the serial port a float
            new_value = temp_temp.save_value({'value':float_current_temp}) #sending value to ubidots
            print ("sending successful")
Video explaining Arduino sketch and Python script, as well as providing introduction to Ubidots:
Please comment. Any feedback is very valuable for me, especially constructive criticism. If you like what I'm doing you can subscribe my channel on YouTube (https://www.youtube.com/user/W0j45), follow me on Twitter (https://twitter.com/milczarekw) and Instagram (https://www.instagram.com/milczarekw/).
Thank you for reading!
  • dragonboliero
    dragonboliero over 10 years ago in reply to neilk +1
    Hello Neil, Did you share your project somewhere? I would really like to see it if its possible. I'm really happy that you liked my entry. Best regards, Wojtek
  • neilk
    neilk over 10 years ago
    Hi dragonboliero  Very nice post; thanks image . I've done something similar, but I posted my data to my local website & then grabbed it from the website display using Microsoft Excel for graphing.
    Great to hear about Ubidots and also learn a bit of Python!
    Thanks again
    Neil
  • dragonboliero
    dragonboliero over 10 years ago in reply to DAB
    Thank you. I know it doesn't do much, however it's my first step to making weather station (it'll also provide data such as atmospheric pressure, humidity and maybe some other data such as wind speed).
    DAB over 10 years ago
    Nice post.
    You never know when you need to log data.
