Arduino Projects
Arduino Projects
Blog LEGO Train Track Switch - Servo, LED, PubNub and Node-RED
  • Date Created: 7 Jan 2016 1:26 AM Date Created
  • Views 1444 views
  • Comments 7 comments
  • LEGO
  • node-red
  • nodejs
  • raspberrypi
  • iot
  • pubnub
e14 Contributor
e14 Contributor
7 Jan 2016
I've been working on this Arduino project for a while. Mostly mechanical issues, but finally got a solid solution for my LEGO train track switch. I am also using IoT style messaging to emulate a distributed network of "things". It's a little overkill for a single track switch, but it helps to understand the bigger picture with these types of technologies. I plan on integrating this with a train schedule API so I can send the train down a path based on real-world data. I also have an OLED display in the mail, so will be cool to show train times as well.
Train Track Switch – Servos, LEDs, PubNub and Johnny-five.io | Internet of Lego
    e14 Contributor over 10 years ago in reply to mcb1 +2
    Hey Mark, I figured I should describe the mechanics a bit more, since that's what took me ages to sort out. I took a bunch of photos that should help describe how I did it. The hardest part was using a…
    mcb1 over 10 years ago in reply to e14 Contributor
    I'll pass it on to the man.
    he did comment about the force required, and you've nailed how you did it.
    Cheers
    Hey Mark,
    The hardest part was using a 5g hobby servo to pull that stiff switch. Tried various gears and lever situations, but they all got really big and clumsy. I finally just attached a small wire to a technic stud and the servo arm. I then used a small technic pin to connect the stud to the switch lever. I have a small 45 degree 1x1 brick n the floor to guide the technic stud in the correct path. If not, the servo tends to get jammed.     https://www.facebook.com/media/set/?set=a.1671388719799991.1073741835.1636231349982395&type=1&l=c9d0cad8a9
    Hope this helps!
    I was wondering if you might consider detailing the mechanical aspect.
    We have a Lego train guy at work who has been considering adding electronics to his displays, but the switching was an aspect that didn't appear to have an easy solution.
    Thanks
    DAB over 10 years ago
    Very nice build.
    Great way to combine a couple of different hobbies into some fun.
  • neilk
    neilk over 10 years ago
    Nice project image..........also looked at your other stuff on fb - very impressive.
    Neil
