Arduino Projects
Arduino Projects
Blog Maccanum Robot Wireless
  • Author Author: fabiolus
  • Date Created: 25 Jun 2025 1:59 PM Date Created
  • Views 390 views
  • robot
  • Maccanum
  • wireless
fabiolus
fabiolus
25 Jun 2025
project:
https://github.com/Fabiolus2020/MaccanumRobotWireless
video demo:
controller sketch
//Fabiolus 2021/07/23
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 myRadio(8, 9); // CE, CSN
//address through which two modules communicate.
const byte address[6] = "00001";
//data being sent to the receiver, joystick position, pot values and button count.
struct package
  int joyposX;
  int joyposY;
  int potValue;
  int stateNum;
  int SideWayRightState;
  int SideWayLeftState;
  int ForwardRightState;
  int ForwardLeftState;
  int BackwardRightState;
  int BackwardLeftState;
//define object for wieless communication
typedef struct package Package;
Package data;
// Define Joystick Connections
#define joyY A0
#define joyX A1
// Define Joystick Values - Start at 512 (middle position) this might change depending on batteries and motor type.
int joyposX = 512;
int joyposY = 512;
//int modeCount;
//defining joystick button followed by declaring variables and build mechanical state machine to keep count of joystick and have 3 modes
const int buttonPin  = 7;
int buttonState      = 0;     // current state of the button
int lastButtonState  = 0;     // previous state of the button
int modeState        = 0;     // remember current led state
int stateNum;
//LED pin only two modes for this robot
#define ledModeStatusCount A3
// Set initial motor speed at 0
int motorspeedModeOne = 0;
int motorspeedModeTwo = 0;
// Set button for diagonal mode drive, upon pushing button specific direction is iniated.
#define buttonSideWayRight 0
#define buttonSideWayLeft 6
#define buttonForwardRight 2
#define buttonForwardLeft 3
#define buttonBackwardRight 4
#define buttonBackwardLeft 5
//Define potentiometer
#define Pot A2
int potValue = 0;
void setup() {
  Serial.begin(9600);           // set up Serial library at 9600 bps
  //define Radio as object
  myRadio.begin();
  //set the address
  myRadio.openWritingPipe(address);
  myRadio.setPALevel(RF24_PA_MAX);
  myRadio.setDataRate( RF24_250KBPS );
  myRadio.setChannel(115);
  //Set module as transmitter
  myRadio.stopListening();
  pinMode(ledModeStatusCount, OUTPUT);
  digitalWrite(ledModeStatusCount, LOW);
  //joystick select/push button
  pinMode(buttonPin, INPUT_PULLUP);  // initialize the button pin as a input
  pinMode(buttonSideWayRight, INPUT_PULLUP);
  pinMode(buttonSideWayLeft, INPUT_PULLUP);
  pinMode(buttonForwardRight, INPUT_PULLUP);
  pinMode(buttonForwardLeft, INPUT_PULLUP);
  pinMode(buttonBackwardRight, INPUT_PULLUP);
  pinMode(buttonBackwardLeft, INPUT_PULLUP);
  delay(10);
void loop() {
  //prepare to capture data to pass wirelessly using data for identifier.
  myRadio.write(&data, sizeof(data));
  // read the pushbutton input pin
  buttonState = digitalRead(buttonPin);
  // check if the button is pressed or released
  // by comparing the buttonState to its previous state, this is the best I could get to being bulletproof and no debouning effect using joystick
  if (buttonState != lastButtonState) {
    // change the state of the led when someone pressed the button
    if (buttonState == 0) {
      data.stateNum++;
      if (data.stateNum > 2) data.stateNum = 0;
    // remember the current state of the button
    lastButtonState = buttonState;
  data.joyposX = analogRead(joyX);
  data.joyposY = analogRead(joyY);
  data.potValue = analogRead(Pot);
  // Serial.print(data.joyposX);
  // Serial.println("joyposX");
  // Serial.println(data.joyposY);
  // Serial.println("joyposY");
  // Serial.println(data.potValue);
  //Serial.println(data.stateNum);
  if (digitalRead(buttonSideWayRight) == LOW) {
    data.SideWayRightState = 0;
  else {
    data.SideWayRightState = 1;
  if (digitalRead(buttonSideWayLeft) == LOW) {
    data.SideWayLeftState = 0;
  else {
    data.SideWayLeftState = 1;
  if (digitalRead(buttonForwardRight) == LOW) {
    data.ForwardRightState = 0;
  else {
    data.ForwardRightState = 1;
  if (digitalRead(buttonForwardLeft) == LOW) {
    data.ForwardLeftState = 0;
  else {
    data.ForwardLeftState = 1;
  if (digitalRead(buttonBackwardRight) == LOW) {
    data.BackwardRightState = 0;
  else {
    data.BackwardRightState = 1;
  if (digitalRead(buttonBackwardLeft) == LOW) {
    data.BackwardLeftState = 0;
  else {
    data.BackwardLeftState = 1;
    Serial.println(data.SideWayRightState);
   Serial.println(data.SideWayLeftState);
   Serial.println(data.ForwardRightState);
   Serial.println(data.ForwardLeftState);
   Serial.println(data.BackwardRightState);
   Serial.println(data.BackwardLeftState);
receiver sketch:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor1 = AFMS.getMotor(1);
Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2);
Adafruit_DCMotor *myMotor3 = AFMS.getMotor(3);
Adafruit_DCMotor *myMotor4 = AFMS.getMotor(4);
#include <SPI.h>
#include <RF24.h>
struct package
  int joyposX;
  int joyposY;
  int potValue;
  int stateNum;
Package data;
void setup() {
  Serial.begin(9600);
  AFMS.begin(4000);  // OR with a different frequency, say 4KHz
  while (!Serial);
  myRadio.begin();
  //set the address
  myRadio.openReadingPipe(0, address);
  //Set module as receiver
  myRadio.startListening();
void loop() {
  if ( myRadio.available())
    myRadio.read( &data, sizeof(data) );
    if (data.joyposX < 485)//Going Forward
      if (data.stateNum == 1)
        myMotor1->run(FORWARD);
        myMotor2->run(FORWARD);
        myMotor3->run(FORWARD);
        myMotor4->run(FORWARD);
        motorspeedModeOne = map(data.joyposX, 485, 0, 0, 255);
        myMotor1->setSpeed(motorspeedModeOne);
        myMotor2->setSpeed(motorspeedModeOne);
        myMotor3->setSpeed(motorspeedModeOne);
        myMotor4->setSpeed(motorspeedModeOne);
      else if (data.stateNum == 2)
        motorspeedModeTwo = map(data.potValue, 0, 1023, 0, 255);
        myMotor1->setSpeed(motorspeedModeTwo);
        myMotor2->setSpeed(motorspeedModeTwo);
        myMotor3->setSpeed(motorspeedModeTwo);
        myMotor4->setSpeed(motorspeedModeTwo);
    if (data.joyposX > 600)//Going Backward
        myMotor1->run(BACKWARD);
        myMotor2->run(BACKWARD);
        myMotor3->run(BACKWARD);
        myMotor4->run(BACKWARD);
        motorspeedModeOne = map(data.joyposX, 600, 1023, 0, 255);
      else if (data.stateNum == 2)//Going Backward
    if (data.joyposY > 600)//Going left
        motorspeedModeOne = map(data.joyposY, 600, 1023, 0, 255);
      else if (data.stateNum == 2)//Going left
    if (data.joyposY < 470)//Going right
        motorspeedModeOne = map(data.joyposY, 470, 0, 0, 255);
      else if (data.stateNum == 2)//Going right
    if (data.SideWayRightState == 0) {//GREEN BUTTON
        myMotor1->setSpeed(255);
        myMotor2->setSpeed(255);
        myMotor3->setSpeed(255);
        myMotor4->setSpeed(255);
    if (data.SideWayLeftState == 0) {//GREEN BUTTON
    if (data.ForwardRightState == 0) {//YELLOW BUTTON
        myMotor1->run(RELEASE);
        myMotor2->run(RELEASE);
    if (data.ForwardLeftState == 0) {//YELLOW BUTTON
        myMotor3->run(RELEASE);
        myMotor4->run(RELEASE);
    else if (data.BackwardRightState == 0) {// BLUE BUTTON
    else if (data.BackwardLeftState == 0) {// BLUE BUTTON
controller schema
https://github.com/Fabiolus2020/MaccanumRobotWireless/blob/main/controller_bb.png
receiver schema:
https://github.com/Fabiolus2020/MaccanumRobotWireless/blob/main/receiver_bb.png
