Arduino Projects
Arduino Projects
Blog MeArm-RL-PyBullet
  • Author Author: lucaeffe03
  • Date Created: 29 Oct 2026 12:36 PM Date Created
  • Views 136 views
  • Comments 5 comments
MeArm-RL-PyBullet
lucaeffe03
lucaeffe03
29 Oct 2026
A 4DOF Keyestudio KS0198X robotic arm trained in simulation using reinforcement learning to reach a target, and transferred via serial to the physical arm. Task: reach — moving the tip of the arm (tool) towards a red dot generated within the arm's real workspace, using PPO (Proximal Policy Optimization, Stable-Baselines3) on a PyBullet model built from the real URDF/meshes of the mechanism.
Devices & Components
1image
Arduino Uno Rev3
1 image
4DOF Robot Arm Kit
Mearm_real_env.py
Gymnasium environment for the MeArm/Keyestudio KS0198X robotic arm, simulated in PyBullet from the real URDF (URDF and mashes available on GitHub).
Neural network (view code on GitHub):
An input layer with 17 neurons (one for each observation value: 4 (positions) + 4 (velocities) + 3 (ee_pos) + 3 (target_pos) + 3 (delta_pos))
An output layer with 4 neurons (one for each motor).
Serial_bridge.py
Sim-to-real bridge: reads a trained policy and sends the corresponding servo angles to the physical Keyestudio arm via serial.
Train.py
PPO training (with linear reward) of the 'reach' task on the real MeArm model.Run on an M1 for 1M steps across 4 parallel environments (you can use even more steps if necessary for your specific case). PPO takes the data from all 4, averages it, and updates the weights much more stably.To monitor training progress with TensorBoard, open the terminal:tensorboard --logdir ./tb_logs/"
Evaluate.py
Loads the trained model and shows it in action within the PyBullet GUI.
CODE
MeArm-RL-PyBullet
    DAB 25 days ago +1
    Looks like a good learning tool.
  • cstanton
    cstanton 24 days ago +1
    Hey lucaeffe03 , interesting set of projects with the 'mearm' here, is this a project you did out of interest for it, or were sponsored, or did you do it for a school project? I'd be interested in your…
  • cstanton
    cstanton 24 days ago in reply to lucaeffe03 +1
    We have a Robotics design challenge coming up (keep your eyes on the homepage or design challenge group ;) ) you might want to consider applying for!
  • mearm.ben
    mearm.ben 23 days ago
    Great project, thanks for including the original product name with it. Keystudio have unapologetically exploited our open hardware, entirely ignoring the licence and my communications over several years. What is great is that you've put together some amazing tutorials and shared them in the original spirit of the MeArm project.
  • cstanton
  • lucaeffe03
    lucaeffe03 24 days ago in reply to cstanton
    Hi cstanton :) ,over the last few months I’ve been working on these projects to learn more about robotics and computer vision since we don’t do many practical projects at university, I decided to experiment a bit on my own. I recently discovered this community through Instagram and thought of sharing them. I hope they might be helpful to other users as well :)
  • cstanton
    Hey  lucaeffe03 , interesting set of projects with the 'mearm' here, is this a project you did out of interest for it, or were sponsored, or did you do it for a school project? I'd be interested in your commentary and experiences alongside what you're posting so it's not only a posting of code?
    DAB 25 days ago
