Arduino Projects
Arduino Projects
Blog SmarDen: Sustainable gardening via Dropbox
  • Author Author: rubroe
  • Date Created: 16 May 2015 3:30 PM Date Created
  • Views 987 views
  • solar-powered
  • gardening
  • iot applications
  • mbse
  • sysml
  • dropbox
rubroe
rubroe
16 May 2015
In order to control plants via Dropbox we built the following control circuit / Cyber Physical System (CPS) / Internet of Things application. To support sustainability, the water used is taken out of a natural pond. The required energy is supplied by a solar panel that charges an old automotive accumulator (battery). Images of the plant growth progress and data is being sent to dropbox constantly. This project was part of a thesis and the advanced development / recursive modelling has been performed with SysML to verify applicability of Model Based Systems Engineering (MBSE) in the context of IoT and CPS.
{gallery} Layout
Layout:
Schema:
SysML CPS Profile & abstract reference architecture (1/3):
{gallery} Dropbox GUI and Hardware
Measured data: Battery level; Humidity; Temperature; XBee connection; Water level
Images sent to Dropbox:
Arduino:
Battery:
Arduino code:
#include <MemoryFree.h>
#include <avr/wdt.h>
#include <avr/sleep.h>
#include <avr/power.h>
#include "pb_encode.h"
#include "pb_decode.h"
#include "messages_pb.h"
#include <SoilHumidity2.h>
#include <LM35.h>
//#include <AltSoftSerial.h>
#include <SoftwareSerial.h>
#include <JPEGCamera.h>
// sensors
SoilHumidity2 hsensor(3, 1); // soil resistance sensor: digital out pin, analog in pin
LM35 tsensor(0); // temperature sensor: analog in pin
const int batVPin = 2;   // bat level analog pin
const int waterVPin = 3; // water level in pin
const int waterOPin = 5; // water level sensor digital out pin
const int pumpOPin = 6;  // pump digital out pin
long pumpEndT = -1; // time to turn pump off, -1 if pump is off
long lastCommand = millis(); // time of last command. if we do not receive a command within 2 min. we go to sleep for 56 secs -> save power
int pumpBattLevel = 0;  // level of bat while pumping
const int WATER_LEVEL = 400;
// communication
SoftwareSerial s(8,9);      // cam serial
SoftwareSerial s2(10,11);  // xbee serial
JPEGCamera cam(s);
// xbee comm protocol
const unsigned int MAGIC = 7557; // frame prefix
messages_SensorData sensorData;
messages_Command commandData;
messages_picData picData;
messages_Ok okData;
char rBuffer[16];      // read buffer
uint8_t wBuffer[32];   // write buffer
pb_ostream_t stream;
// xbee comm protocol parsing
int readState = 0; // 0: magic_h, 1: magic_l, 2: len_h, 3: len_l, 4: buffer
int readExpectedLen = 0;
int m;
uint8_t h;
uint8_t l;
uint8_t command = 255;
int command_arg;
// control led
int led = 13;
int value = HIGH;
// power control
volatile long sleepOn = 0;
int powerPin = 12;
void softReset() // Restarts program from beginning but does not reset the peripherals and registers
  asm volatile ("  jmp 0");
ISR(WDT_vect)
  //Serial.println("ISR");
  if (sleepOn > -1)
  else
    softReset();
void setupWDT()
  /*** Setup the WDT ***/
  /* Clear the reset flag. */
  MCUSR &= ~(1<<WDRF);
  /* In order to change WDE or the prescaler, we need to
   * set WDCE (This will allow updates for 4 clock cycles).
  WDTCSR |= (1<<WDCE) | (1<<WDE);
  /* set new watchdog timeout prescaler value */
  WDTCSR = 1<<WDP0 | 1<<WDP3; /* 8.0 seconds */
  /* Enable the WD interrupt (note no reset). */
  WDTCSR |= _BV(WDIE);
void enterSleep()
//   set_sleep_mode(SLEEP_MODE_PWR_SAVE);   /* EDIT: could also use SLEEP_MODE_PWR_DOWN for lowest power consumption. */
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);   /* EDIT: could also use SLEEP_MODE_PWR_DOWN for lowest power consumption. */
  /* Now enter sleep mode. */
  sleep_enable();
  sleep_mode();
void camSave()
   s.begin(38400);
    s.listen();
  wdt_reset();
  cam.reset();
  delay(6000);
  wdt_reset();
  cam.powerSaving(true);
void sleepIt(long duration)
  LEDLow();
  sleepOn = duration/8000;
  if (sleepOn == 0)
    sleepOn = 1;
  digitalWrite(powerPin, LOW);
  while (sleepOn)
    enterSleep();
  /* The program will continue from here after the WDT timeout*/
    sleepOn--;
  sleep_disable(); /* First thing to do is disable sleep. */
  /* Re-enable the peripherals. */
  power_all_enable();
  delay(100);
  digitalWrite(powerPin, HIGH);
// camSave();
// parse xbee comm
void doSerial()
  s2.listen();
  //Serial.println("event");
  while (s2.available())
    invertLED();
    switch (readState)
    case 0:
      h = s2.read();
      if (h == highByte(MAGIC))
        readState = 1;
      break;
    case 1:
      l = s2.read();
      m = word(h,l);
      if (m != MAGIC)
        readState = 0;
      else
        readState = 2;
      m = 0;
      break;
    case 2:
      h = s2.read();
      readState = 3;
      break;
    case 3:
      l = s2.read();
      readExpectedLen = word(h, l);
      // Serial.print("len ");
      //  Serial.println(readExpectedLen, DEC);
      if (readExpectedLen > 32)
        readState = 0;
      else
        readState = 4;
      break;
    case 4:
      if (s2.readBytes(rBuffer, readExpectedLen) == readExpectedLen)
        pb_istream_t stream = pb_istream_from_buffer((uint8_t *)rBuffer, sizeof(rBuffer));
        pb_decode(&stream, messages_Command_fields, &commandData);
        command = commandData.command;
        //  Serial.print(7,DEC);
        //  Serial.println(command,DEC);
      readState = 0;
      break;
    default:
      readState = 0;
      break;
void setup()
  stream = pb_ostream_from_buffer(wBuffer, sizeof(wBuffer));
  s2.begin(9600);    // set low xbee baudrate to reduce error rate.
  s.begin(38400);    // default cam baudrate is 38400
//  Serial.begin(9600);  // use serial for debug, but may block if used together with software serial
//  Serial.println("setup");
  pinMode(led, OUTPUT);
  pinMode(batVPin, INPUT);
  pinMode(waterVPin, INPUT);
  pinMode(waterOPin, OUTPUT);
  pinMode(pumpOPin, OUTPUT);
  pinMode(powerPin, OUTPUT);
  // turn xbee on
setupWDT();
// camSave();
// set LED to high
LEDHigh();
   // wdt_enable(WDTO_8S);   // set watchdog to 8 seconds. may be set lower in future
void loop()
  wdt_reset();   // trigger watchdog
  if (pumpEndT > 0 && pumpEndT < millis())  // check if pump is on
    offPump();
  doSerial();  // parse input
  if (command < 255)  // if we received a command: execute it
    invertLED();
    wdt_reset();
    doCommand();
    command = 255;
    // Serial.print(0,DEC);
    // Serial.print(command, DEC);
  else
    if (pumpEndT <= 0 && (millis() - lastCommand) > 60000)
      sleepIt(56000);
      lastCommand = millis()-55000;
void LEDHigh()
   value = LOW;
invertLED();
void LEDLow()
   value = HIGH;
invertLED();
void invertLED()
  if (value == HIGH)
    value = LOW;
  else
    value = HIGH;
  digitalWrite(led, value);
void doPump()
  pb_ostream_t stream = pb_ostream_from_buffer(wBuffer, sizeof(wBuffer));
  if (pb_encode(&stream, messages_Ok_fields, &okData))
    //Serial.print("b ");
    //Serial.println(stream.bytes_written, DEC);
     sendMessage(stream.bytes_written);
//     else
//  Serial.println("error encoding ok in doPump");
  long duration = commandData.arg;
// Serial.print(millis(), DEC);Serial.print(" doPump ");Serial.println(duration, DEC);
  if (duration > 0)  // duration 0 == heart beat
    pumpEndT = millis()+duration;
    digitalWrite(pumpOPin, HIGH);
    delay(500);
    pumpBattLevel = getBatLevel(); // get bat level only when bat is under load
void doSleep()
  pb_encode(&stream, messages_Ok_fields, &okData);
    sleepIt(duration);
int getBatLevel()
   return analogRead(batVPin);
void getWaterLevel()
  digitalWrite(waterOPin, HIGH);
  delay(500);
  int x = analogRead(waterVPin);
  digitalWrite(waterOPin, LOW);
  bool hasWater = x > WATER_LEVEL;
  sensorData.hasWater = hasWater;
void offPump()
  //  Serial.print(millis(), DEC);Serial.println(" offPump");
  pumpEndT = -1;
  digitalWrite(pumpOPin, LOW);
void sendPic()
  // Serial.println();
  // Serial.println(9, DEC);
  // Serial port connected to the cam
  s.listen();
  delay(1000);
  cam.reset();
  delay(4000);
  wdt_reset();
// cam.powerSaving(false);
  delay(50);
   cam.chBaudRate(1);
   delay(50);
   s.end();
   s.begin(19200);
   delay(50);
  invertLED();
  cam.takePicture();
  wdt_reset();
  delay(25);
  picData.size = cam.getSize();
  pb_encode(&stream, messages_picData_fields, &picData);
  delay(10);
  invertLED();
  wdt_reset();
  cam.readData(s2);
  s2.flush();
  cam.stopPictures();
  invertLED();
void sendSensorData()
  wdt_reset();
  sensorData.temperature = tsensor.temperature();
  wdt_reset();
  sensorData.humidity = hsensor.humidity();
  wdt_reset();
  if (pumpBattLevel > 0)
    sensorData.batLevel = pumpBattLevel;
    pumpBattLevel = 0;
  else
    sensorData.batLevel = getBatLevel();
  getWaterLevel();
  pb_encode(&stream, messages_SensorData_fields, &sensorData);
void sendMessage(size_t len)
// Serial.print("send ");Serial.println(len, DEC);
  sendStartMessage(len);
  s2.write(wBuffer, len);
  s2.flush();
  delay(100);
  //Serial.println("endsend");
void sendStartMessage(size_t len)
  s2.write(highByte(MAGIC));
  s2.write(lowByte(MAGIC));
  s2.write(highByte(len));
  s2.write(lowByte(len));
void doCommand()
  // Serial.print(8,DEC);
  switch (command)
  case 0:
    sendSensorData();
    break;
  case 1:
   doPump();
    break;
  case 2:
    sendPic();
    break;
  case 3:
    doSleep();
    break;
  default:
    break;
BoM:
Raspberry Pi B+
Arduino Pro Mini
XBee
Charge Controller
Solar Panel
12V Battery
Temp Sensor
Humidity Sensor
Water Pump
Water Level Sensor
LinkSprite JPEG Color - Infrared
Open Source Software Packages:
Yet Another Java Service Wrapper http://sourceforge.net/projects/yajsw/
Yet Another Cron4J http://sourceforge.net/projects/yacron4j/
vfs dropbox plugin http://sourceforge.net/projects/vfs-dbx/
If you have any questions, please dont hesitate to contact us.
Best regards,
Ruben Rösner
    DAB over 8 years ago +1
    Nice update. DAB
    Nice update.
