Arduino
Arduino
Blog [Dynamic Living-Room Lights] The Lights Teaser Video
  • Author Author: ipv1
  • Date Created: 27 Dec 2014 9:39 AM Date Created
  • Views 3254 views
  • Comments 17 comments
  • iot_holidaylights
  • ip_iot
  • holiday_mood
ipv1
ipv1
27 Dec 2014
List of previous posts
  • [Dynamic Living-room Lights] Description
  • [Dynamic Living-room Lights] Simple System Design
  • [Dynamic Living-Room Lights] The YUN review - When the Penguin Met The Arduino.
  • [Dynamic Living-Room Lights] The Infineon RGB LED Shield Review
  • [Dynamic Living-Room Lights] The Infineon RGB LED Shield -Library!
The Teaser
The project documentation is taking forever and I will release it much more systematically. For now, here is a small video of one of the parts which is the audio controlled LED lights. I am using the ARDUINO RGB LED SHIELD, XMC1202ARDUINO RGB LED SHIELD, XMC1202 and an Arduino. I am using an analog filter and the details will be released in an upcoming post.
Cheers,
IP
  • ipv1
    ipv1 over 11 years ago in reply to gadget.iom +2
    Thanks gadget.iom . You should have seem the tektronix Scope when I was doing an I2C Dump! I dare not try the I2C probe with the BusPirate since I would get a gazillion bytes at a time. Anyone have ideas…
    mcb1 over 11 years ago in reply to ipv1 +2
    Inderpreet Attached is a scan of the relevant part of the schematic (way before CAD) used for filtering the audio out and using it to drive the lighting effects. In our application we wanted the bass frequencies…
  • pmohan
    pmohan over 11 years ago +1
    Hey.. That was a cool teaser and you are right about taking forever to document
    shabaz over 11 years ago in reply to mcb1
    Hi Inderpreet!
    Lets do a short non-recorded one next time maybe? webex if possible? But I'm not sure when to suggest in terms of time : ( During weekdays January-Feb is the busiest time of the year for me : (
    We missed both Shabaz sir and you at the hangout last night
    Yeah sorry I missed the time change, and I'm watching it now.
    Anyway another time ...
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to ipv1
    it is probably the fade time or walk times, this is a setting that controls how long it takes to go from one colour to the other or one brilliance to another
    This is my initialization steps
    RGBLEDS.I2CWRITE2BYTES (ADDRESS, OFFTIME_RED, 0x38); // Set off-time of red channel to 0x38
      RGBLEDS.I2CWRITE2BYTES (ADDRESS, OFFTIME_GREEN, 0x39); // Set off-time of green channel to 0x39
      RGBLEDS.I2CWRITE2BYTES (ADDRESS, OFFTIME_BLUE, 0x38); // Set off-time of blue channel to 0x38
      RGBLEDS.I2CWRITE6BYTES (ADDRESS, CURRENT_RGB, 0x80, 0x80, 0x80); // Set current of red channel to 0x80 = 780mA
      RGBLEDS.I2CWRITE2BYTES (ADDRESS, FADERATE, 0x0005); // Fade Rate between intensities --> 0.0s
      RGBLEDS.I2CWRITE2BYTES (ADDRESS, WALKTIME, 0x0010); // walk time between colors = 0s
      RGBLEDS.I2CWRITE6BYTES (ADDRESS, INTENSITY_RGB, 0x0555, 0x0555, 0x0555); // low level White Light
      RGBLEDS.I2CWRITE2BYTES (ADDRESS, DIMMINGLEVEL, 0x0FFF); // Maximum dimming level means intensity settings are directly used
    if you set the value of the two bold lines to zero then it should change instantly
  • ipv1
    ipv1 over 11 years ago in reply to mcb1
    Thanks mark sir,
    The circuit is appreciated.
    In this instance the target is to use the infineon shield because the same lighting is supposed to be controllered over Ethernet as well hence i had to do the whole Arduino thing.
    We missed both Shabaz sir and you at the hangout last night. I will try and schedule one at a more comfortable time the next.
    Cheers,
    Ip
  • ipv1
    ipv1 over 11 years ago in reply to shabaz
    Hi Shabaz sir,
    I think the problem is something with the led strip itself. The inductor needs to release the stored energy and in my vase there is a series resistor which increases the field collapse time. I might try and increase the i2c speed so that the response is quicker though.
    Thanks
    Ip
