Arduino
Arduino
Blog [Dynamic Living-Room Lights] The Lights Teaser Video
  • Author Author: ipv1
  • Date Created: 27 Dec 2014 9:39 AM Date Created
  • Views 3255 views
  • Comments 17 comments
  • iot_holidaylights
  • ip_iot
  • holiday_mood
ipv1
ipv1
27 Dec 2014
List of previous posts
  • [Dynamic Living-room Lights] Description
  • [Dynamic Living-room Lights] Simple System Design
  • [Dynamic Living-Room Lights] The YUN review - When the Penguin Met The Arduino.
  • [Dynamic Living-Room Lights] The Infineon RGB LED Shield Review
  • [Dynamic Living-Room Lights] The Infineon RGB LED Shield -Library!
The Teaser
The project documentation is taking forever and I will release it much more systematically. For now, here is a small video of one of the parts which is the audio controlled LED lights. I am using the ARDUINO RGB LED SHIELD, XMC1202ARDUINO RGB LED SHIELD, XMC1202 and an Arduino. I am using an analog filter and the details will be released in an upcoming post.
Cheers,
IP
  • ipv1
    ipv1 over 11 years ago in reply to gadget.iom +2
    Thanks gadget.iom . You should have seem the tektronix Scope when I was doing an I2C Dump! I dare not try the I2C probe with the BusPirate since I would get a gazillion bytes at a time. Anyone have ideas…
    mcb1 over 11 years ago in reply to ipv1 +2
    Inderpreet Attached is a scan of the relevant part of the schematic (way before CAD) used for filtering the audio out and using it to drive the lighting effects. In our application we wanted the bass frequencies…
  • pmohan
    pmohan over 11 years ago +1
    Hey.. That was a cool teaser and you are right about taking forever to document
    Inderpreet
    Nice effects.
    I'll try to scan the circuit we used in Night Club lighting effects.
    Basically we filtered off the high frequencies, and half wave rectified the remaining audio.
    (from memory) we capacitively coupled to the 'charge pump' and used the peaks to trigger the light change.
    The system always adjusted itself to the volume, and responded to the bass. (or whatever frequency range you want)
    ipv1
    shabaz over 11 years ago in reply to ipv1
    Hi Inderpreet,
    I wonder if the Arduino I2C library has delays between bytes or something. I noticed there is an option to increase the overall interface speed.
    Is that where you are observing delay, or somewhere else?
  • ipv1
    Anyone have ideas on how to make the LEDs respond faster. They are good but I want better.
    Cheers,
    IP
  • ipv1
    ipv1 over 11 years ago in reply to shabaz
    Actually I am redoing the circuit since i got a good response at christmas. I am experimenting with the sallen key archi but have a much better idea.
    I just might try and process the whole filter in the Arduino since I am looking at a lower frequesny range. My problem is that I am running a lot more on the YUN as well so still working at it.
  • gadget.iom
    gadget.iom over 11 years ago
    Like the Oscilloscope VU meter there. image
    Makes a nice visual effect.
