Arduino
Arduino
Blog Fast Track to Arduino Programming - Lesson 4b, How to use an Ethernet Shield with a WEB page
  • Author Author: Robert Peter Oakes
  • Date Created: 22 Jun 2014 10:09 PM Date Created
  • Views 4009 views
  • Comments 14 comments
  • tutorial
  • console
  • ethernet
  • fast_track_to_arduino_programming
  • ws5100
  • wiznet
  • enc28j60
Robert Peter Oakes
Robert Peter Oakes
22 Jun 2014
Link back to main menu Fast Track to Arduino Programming
link to lesson 4a incase you missed it image : Fast Track to Arduino Programming - Lesson 4a, Ethernet input and response test console
In lesson 4a we reviewed the HTML based console that was to be used throughout lesson 4, this was so you are prepared to follow through the lesson without worrying about how other none Arduino parts work, now I will present the main video that will walk you through the sketch, identifying the changes from the previous lesson and explaining the operation of the added code.
this is a long video, close to an hour but I wanted to be thorough and not miss out key parts.
The sketch and HTML page are provided in lesson 4a here: Fast Track to Arduino Programming - Lesson 4a, Ethernet input and response test console
and to follow up with how to change the settings of the web page and a brief description as to how it works, see this
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to brunosurf17
    I tried this on one of my UNO boards and it works ok, the code does have two ehternet cards available to it, a WIZNET and the ENC26 chip. Do you have the right library selected ?
    Peter
  • brunosurf17
    brunosurf17 over 11 years ago
    Hello Peter.
    Thank you for your attention, my code and configuration is as follows:
    Lesson 4:
    var myIPaddress = "http://192.168.1.247/";
          var analogAlljson = "analogAlljson";
          var digitalAlljson = "digitalAlljson";
    Arduino:
    byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xaa };
    IPAddress ip(192,168,1,247);
    IPAddress dns1(192,168,1,1);
    IPAddress gateway(192,168,1,1);
    IPAddress subnet(255,255,255,0);
    EthernetServer server(80); // use standard port 80
    The other parts of this code the same as files GITHUB.
    thank you very much
    Hi Bruno
    Can you also post your sketch as you have changed it and I will see if I can find what is wrong. Also you wont be able to ping the Arduino, the stack (Code) does not support PING.
    Thanks
    Peter
  • brunosurf17
    Personally, I am unable to capture the state of the Arduino doors, changed the ip configurations in Arduino and html according to my network, I tested other browsers and poblema persists.
    I can trigger all the pins, but this being possible to read the entries
    I can ping the Arduino still not working.
    what should I be doing wrong?
    Since already thank you.
  • vish
    vish over 12 years ago in reply to vish
    forgot to mention, I'm talking about the line numbers in oscilloscope.html file
