Arduino
Arduino
Blog Testing Sensors on the Arduino Uno R4
  • Author Author: fmilburn
  • Date Created: 30 Jul 2023 4:17 AM Date Created
  • Views 4860 views
  • Likes 17 likes
  • Comments 19 comments
  • infineon
  • sensors
  • rohm
  • arduino uno r4 wifi
  • arduino uno R4
fmilburn
fmilburn
30 Jul 2023
I've been going through my parts collection to see what sensors I have that might be easily used with the Uno R4 that element14 and Arduino were kind enough to send me.  I was surprised at how much I had readily available.
I did a RoadTest on the Infineon Getting Started Box IOT a few years back. It contains a number of sensors and a shield that fits the Uno form factor.
I also did a RoadTest of the Rohm SensorShield-EVK-003 with 8 sensors with an Uno-compatible shield.
I did limited testing with these two and they seem to be compatible with the Uno R4.  Both do bi-directional signal  conversion to 3V3 on the shield and appear to use the standard I2C Arduino calls.
Of course, there are many more options.  I was recently at a conference where they had a table to share your unwanted electronics and picked up a shield with lots of connections on top.  I also found one in my old Arduino "stuff" with connections and an SD card slot.
And to top it off I ordered a package of ready-made Qwiic cables since the Uno R4 WiFi board has a Qwiic connector on it.
I don't have any sensors with Qwiic connections but the package has a connector with duPont pins so I can rig something up on a breadboard for sensors with I2C.  Or I could cut a connector in half and solder the end to a sensor package.
Now I need a project. For some reason all this stuff scattered on my bench made me think of the Star Trek Tricorder.
Photo credit:  Cardboard prop by PartyTime
Maybe I could 3D print something with that nice '60s aesthetic of the original series and pack it with sensors.  There would be plenty of room inside for an Uno.  That's why I've started to test a TFT display with the Rohm sensor shield.
  • baldengineer
    baldengineer over 3 years ago in reply to fmilburn +1
    Thanks for sharing my TNG-inspired tricorder. Some day, I'd like to redo it with an appropriate sensor package. (And an enclosure better designed for 3d printing!)
    beacon_dave over 3 years ago in reply to fmilburn +1
    "...I can only work on this every few days..." Well, watching past episodes of Star Trek whilst researching tricorders takes time. It is looking like it is off to a great start. "Can you tell what…
    dougw over 3 years ago in reply to fmilburn
    reusable and scalable IP....Relaxed
    I think it must have matched on your legs... Slight smile
  • fmilburn
    fmilburn over 3 years ago in reply to beacon_dave
    I did a search with Google Lens.  It thought that among other things it might be a waste disposal receptacle. That is humbling.
    Well, watching past episodes of Star Trek whilst researching tricorders takes time.  Slight smile
    "Can you tell what it is yet?" - Bing's 'visual search' hasn't quite worked it out yet... Obviously not trained on enough Sci-Fi content. Slight smile
  • fmilburn
    Here is the first actual 3D model.  The dimensions are not final and not all the bits and bobs are there but it is close to something that could be printed.  I can only work on this every few days but I thought I'd update in the hopes it would keep the pressure on me to make progress.
