Arduino Forum Low footprint http post of json data
  • Replies 7 replies
  • Subscribers 415 subscribers
  • Views 1300 views
easyejl
easyejl over 6 years ago
What library do you think is best to allow posting of json data (with no concern for reply) on an arduino with an ethernet shield?
    Jan Cumps over 6 years ago in reply to easyejl +3
    The MKR1xxx WiFi or the one with a ethernet shield can do valid json over HTTPS with valid certificate. I used that combination with AWS . Blogged the process here on e14. I’ll try to find the post...
    Jan Cumps over 6 years ago in reply to Jan Cumps +3
    update: Arduino MKR WIFI 1010 and Amazon Web Services: Safe MQTT with SSL and Certificate both wifi and ethernet were tested
  • fmilburn
    fmilburn over 6 years ago +1
    Hi Eric, I am not proficient with JSON but did use ArduinoJson with a project. It is well documented and supported. Frank
  • easyejl
    To be clear, https with a valid certificate
  • fmilburn
    Hi Eric,
    Frank
    shabaz over 6 years ago in reply to easyejl
    Hi Eric,
    HTTPS might be hard, I don't know if Arduino boards have the resources for that. Which particular board are you using?
  • easyejl
    easyejl over 6 years ago in reply to shabaz
    an Elegoo Uno R3. I ended up so far finding a library that directly handled dweet.io so I have that going. I think i'll be able to modify it for use with azure or amazon and elastic search. Still hard to tell if I'll run into memory footprint issues. Not really used to that myself image
  • easyejl
    easyejl over 6 years ago in reply to Jan Cumps
    That's pretty cool. It helps a good bit, maybe my real issue is that the Uno R3 isn't my best choice of board to start with image
