Arduino Forum motor drive
  • Subscribers 414 subscribers
  • Views 570 views
motor drive
tsla
tsla over 6 years ago
now i will hold my hands up this is probalbily easy to do but i am new to arduino but basicaly its a method to open a door yes i know it would be done easyer but this is what fits the space i have and i know i could do it all manuely with switches and that but i wanted basicaly a 2 button oparation one to open one to close.
so how i see it working is i use one push button to open and you have 4 motors that run together to push the door out till it hits a limit swich and then useing 2 more motors it lifts the door up till it hits a limit switch
and to close its just to opasit you push another button that lowers the door till it hits a limit swich and pulls the door back in till it hits a limit swich
    shabaz over 6 years ago +2
    Hi Scott, What you're describing is quite hard to do, especially for a beginner. On the surface it sounds easy, but anything electronic + mechanical becomes awkward due to needing to consider the success…
  • gadget.iom
    gadget.iom over 6 years ago +1
    shabaz has given some great advice here. I would also strongly recommend starting out with some simple switches and LED's until you get your logic sorted out, motors add a level of physical motion that…
    Hi Scott,
    What you're describing is quite hard to do, especially for a beginner. On the surface it sounds easy, but anything electronic + mechanical becomes awkward due to needing to consider the success and failure situations, such as delays due to things getting stuck, abort/back-out situation, limit switch failures, etc. Electrically you'd have to deal with stalls (high current), possibility of resets and so on.
    So, there is no easy answer, but to get the knowledge to begin prototyping this, you'll probably want to do some basic Arduino tutorials, concentrating on the areas of switching LEDs on and off with push buttons, reading inputs, working with loops and timers and state machines. If you're a beginner then from the software perspective you're likely a month away from doing that, you'll need to go through some training and practical experiments first. Start with simple projects and build up the knowledge.
  • gadget.iom
    shabaz has given some great advice here. I would also strongly recommend starting out with some simple switches and LED's until you get your logic sorted out, motors add a level of physical motion that could have disastrous consequences while experimenting.
    After getting some LED's and switches working the next important step will be looking at State Machines as shabaz also suggested. They are implemented in most Arduino projects, and will be used to manage the stages of your program execution. eg. "Door closed", "Push Out", "Lift Up", "Door Open", "Pull Down", "Pull In".
    The Arduino has a serial monitor, so you can also add some Serial.println commands to log the various stages of your program.
