Arduino Forum Have a question about Arduino? Ask me!
  • Replies 1914 replies
  • Subscribers 527 subscribers
  • Views 70009 views
  • jeremy_blum
  • expert
  • student
sciguy14
sciguy14 over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Questionabout Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Jeremy Blum
Jeremy is an Electrical and Computer Engineering Student at Cornell University. He has been building microcontroller projects since high school, from a prototype prosthetic hand with a novel control scheme, to a nerf gun that fires at the intruders and uploads their picture to the web.
  • billabott
    billabott over 13 years ago in reply to e14 Contributor +2
    @Brendan Your video is somewhat adequate for the intended purpose, however, from an engineer's point of view it is lacking in providing pertinent facts. Such as the part number, data sheet, and source…
    e14 Contributor over 15 years ago +1
    Jeremy, thanks for your intro videos. I am just getting started myself in Arduino though I have done some simple electronics projects using Atmel chips. Here is an example using ATTiny13 chips. www.youtube…
    Hi Jeremy I've built a device (see picture) with an Arduino and Ethernet shield that connects to our Network Monitor (Nagios) and moves an arrow to indicate if any of the computers we monitor are not responding…
  • tronixstuff
    tronixstuff over 15 years ago in reply to e14 Contributor
    No offence, but how long is a piece of string? image
    Search for 'Arduino' in this site -  http://letsmakerobots.com/ to get some ideas about what sort of things you want your robot to accomplish, etc.
    congratulations for your work, I think I found the perfect place for my progect.
    the two years started my progect ROV but with some change advice in my life, I had to stop. something in me made me believe I was able to finish, thanks to you I woke up and started again, I already have some of the material in my office and I'm buying a module for Arduino. I have some doubts whether this board allows a serial rs485 I would like to help if possible
    hi,
    My atmega don't have a bootloader, how can I upload a program in my atmega 328p-pu?
    thanks in advance
    bye
    Ugnius
  • sciguy14
    sciguy14 over 15 years ago in reply to bobcroft
    Yes, but you'll need an ICSP programmer to load the program on and bypass the arduino bootloader.
  • sciguy14
    sciguy14 over 15 years ago in reply to e14 Contributor
    You need to burn the arduino bootloader onto the atmega chip before you can program it with the arduino IDE.
  • sciguy14
    I'm not certain.  It could be a bug in the arduino IDE...
  • sciguy14
    IF you have a new chip, you need a way to burn the bootloader onto it before you can program it with the arduino language.  See here: http://www.arduino.cc/en/Main/Bootloader
  • sciguy14
    You'll need to use inline assembly to make a dealy that short.  With the CPU running at 16MHz, the shortest cycle you can make is 6.25ns.  use the following code to do that.
    __asm__("nop\n\t");
  • sciguy14
    You'll need to at least solder a header connection into those holes, you can then use a connector if you want.
  • sciguy14
    Yes, you can do RS4285 communication, but you'll need a transceiver chip like this these: http://www.newark.com/jsp/search/browse.jsp?N=200718+810017209&No=0&getResults=true&appliedparametrics=true&locale=en_US&divisionLocale=en_US&catalogId=&prevNValues=200718&filtersHidden=false&appliedHidden=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D200718%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_US%26divisionLocale%3Den_US%26catalogId%3D%26prevNValues%3D200718
