Arduino Forum Matrix LED 50x70
  • Replies 11 replies
  • Subscribers 417 subscribers
  • Views 1859 views
  • open-source
  • lighting
  • make
  • diy
  • led
Matrix LED 50x70
I would like to create a 70x50 matrix of LED using the arduino, any idea how to do?
    I will use as an energy source for a 16v car battery
  • fustini
    fustini over 14 years ago in reply to e14 Contributor
    Do you already have LED dot matrix components (like 5x7 or 8x8) or do you have a part that is 70x50?
    Another method is to build the whole matrix out of individual LEDs like this NerdKits project:
    http://www.nerdkits.com/videos/ledarray2/
    Cheers,
    Drew
    e14 Contributor over 14 years ago in reply to fustini
    I am building a 50x70 matrix, do you think best split it into smaller pieces?
  • fustini
    50x70 is bigger than most DIY LED matrixes I've seen (3, 500 LEDs).  It would probably be difficult (or at least very time consuming) to wire manually like NerdKits does in their project.  I think you'd probably have to integrate many separate LED dot matrix displays.  Hopefully you'll be able to find some for cheap on ebay or some surplus provider.
    I'm curious though - what is your application that you need such a large LED matrix?  What sort of budget do you have for the project?
    Cheers,
    Drew
    I am building a board LEDs to inform drivers about road works on the track, will be placed in a car with a 16v battery.
    The budget is reduced then the motive of doing things in hand.
  • fustini
    Ah ok, roughly what size would the road sign need to be?
    I've used multiple 5x7 LED dot matrix arrays before to construct an LED ticker.  Here an example of a 2" 5x7 module:
    http://www.newark.com/vcc-visual-communications-company/vaom-c20571s-bw-40/led-dot-matrix-53-1mmx37-8mm-5x7red/dp/79R5612
    It's $3.25 each.  For 50x70, you'd need a 100 of these.  Theres is a price break at $100, so it would be $2.75 each or $275 total.  That is more expensive than buying 3,500 LEDs but you don't have to worry about manual assembling.
    These modules are 53.1 mm x 37.8 mm, so 100 would yield 5.31 m by 3.79 m.  So for my non-metric mind, that is about 17' x 12'.
    Drew
    michaelkellett over 14 years ago in reply to fustini
    @drew
    square root failure ! (or x 10 failure :-)
    53.1 * 10 = 531mm
    37.8 * 10 = 378mm
    20.9" x 14.9" so at least he won't need truck !
    It's still quite a challenge - if all 3500 are lit up with 10mA the total current is 35A.
    It will need a lot of drivers (75) capable of switching at least 5A (or perhaps 57 switching 7A depending on how the 5x7 modules are connected inside).
    If it was needed to be bright then you might want 5x that current !
    e14 Contributor over 14 years ago in reply to michaelkellett
    How could calculate the circuit, I have available a 16v battery, this array will expend too much energy?
  • fustini
    fustini over 14 years ago in reply to michaelkellett
    Hah, I knew I had a bad feeling about that - guess I shouldn't try to do math while on conference calls.  Thanks for catching that!
    Good point about driving the array.
  • fustini
    fustini over 14 years ago in reply to fustini
    In regards to size, 20" x 15" probably isn't big enough for a road sign.  I think LED dot matrix modules with bigger dot size and overall dimensions would probably be needed.  Knightbright offers up to 4" 5x7 modules:
    http://www.kingbrightusa.com/category.asp?catalog_name=LED&category_name=KCDot+Matrix&Page=1
    I didn't find anything larger in browsing right now, and I'm not sure if that would be big enough for your application.
