Arduino Forum Wireless,ZigBee,XBee-PRO Extended Range Embedded RF Module with U.FL connector
  • Subscribers 416 subscribers
  • Views 403 views
I have 3 Xbee RF module. But I noticed that the U.FL antennae is not included in the package.
Can I use this without the antennae?
Is there any difference in terms of distance range between with and witout the antennae? If yes, what are those?
http://philippines.rs-online.com/web/p/products/6672998/?searchTerm=667-2998&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B337D5B5C732D2F255C2E5D5C647B332C347D2426706F3D3126736E3D592673743D52535F53544F434B5F4E554D424552267573743D3636372D323939382677633D4E4F4E4526
    Yes, they can be used without an antenna. Infact, i used the RPSMA xBee without its Duck antenna and it worked fine upto a very good range (a few meters).
    Thanks. now my next problem is how to assign an ID to 3 XBee RF modules.
    I have 3 Arduino Uno Boards, 3 XBee Shields and 3 XBee RF modules.
    Can I use my existing hardwares to assign an ID to 3 XBee RF modules?
    I think what you need to do is set up a PAN ID in each xBee. For this, open up X-CTU and go to its last tab (can't remember the name), where there is a Read Button. Then, find PAN ID setting below, which by default is 3332 (guessing!) and change it to the one you like. Also, for setting up a co-ordinator xBee and end-devices for a Mesh Netwrok, you may want to look at this site: http://www.faludi.com/projects/zigbee/
