Arduino Forum arduino switching
  • Replies 7 replies
  • Subscribers 417 subscribers
  • Views 827 views
arduino switching
Seems easy / can it be done ?  want to input 64 momentry switches to toggle latch 64 outputs...any help appreciated
    As long as you have enough 74HC595s to Shift Out and enough CD4021BEs to Shift In with then yes.
    Would that be 8 of each ???  ............do you know if the arduino will interface with the 82C55 PIO chip by intercil
    Yes 8 of each will give you 64 inputs and 64 outputs while only using 6 pin on the arduino.
    From what I can tell the 82C55 is a programmable interface chip. If you know how to use it then you can certainly use an Arduino to control it and its 24 i/o pins but you'll need to program the chip as well as the Arduino to control things. But I wouldn't know where to begin in wiring it to the arduino.
    Ok back to the 74 chips...Im ok with analog but dire with digital so excuse me !!
    Can I setup ,say, 20 memory stores where combinations of the switches can be saved and re-called.
    Thats doable. Its all in how you program the Arduino.
  • Nate1616
    Nate1616 over 14 years ago in reply to e14 Contributor
    yes the 82C55 PIO should work with the arduino.  as for the memory stores that should also work.  ive attached and image that should help you with the wiringimage
    hope this helps
    Hello Michael
    Have basically set this up using shift in and out but don't know how to code this...are there any examples ?  the input switch is required to latch the output toggling it on or off..thanks in advance
    Olech
