Arduino Forum Have a question on Arduino? Ask our expert Simon Monk
  • Replies 437 replies
  • Subscribers 445 subscribers
  • Views 20413 views
patkelly
patkelly over 14 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Arduino in the element14 Community Arduino group.  You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Expertise: imageArduino, .NET Gadgeteer, IOIO, embedded computing, open source hardware
About Simon: Simon is an author, writing books for TAB/McGraw-Hill and O'Reilly. He is best known for his Arduino books: 'Programming Arduino' and '30 Arduino Projects for the Evil Genius'.
Simon has a BSc. in Cybernetics and Computer Science and a PhD. in Software Engineering. He spent several years as an academic before he returned to industry, co-founding the mobile software company Momote Ltd.
If you need help on anything about Arduino, please post your question here!
If your not already, you'll need to login or register to ask your question - just click reply
The specified item was not found.
    mcb1 over 13 years ago in reply to aml +2
    Aml I presume you have set the board to UNO under tools, along with the Com port. Have you tried at least the first 10 bullet point s under the link see http:// (You can also select it under hlep on the…
  • simon.monk
    simon.monk over 14 years ago in reply to e14 Contributor +1
    @ jagadeshwaran http://arduino.cc/en/Hacking/Bootloader?from=Main.Bootloader
  • simon.monk
    @ang. This isn't really a task for an Arduino. It does not have nearly enough memory to store a whole image and manipulate it like that. I would not be surprised to find some PC application that would…
    is the arduino uno rev 3 better than arduino leonardo??
  • simon.monk
    It depends what you want to do with it.
    The Leonardo is cheaper and opens up the possibility of making your Arduino act like a USB keyboard and other neat tricks. The only down side is that the processor is SMD. So unlike the Uno where you can just plug in another ATmega328 if you accidentally kill the processor on a Leonardo, you will probably need to get a whole new board.
    I'm keen to try the Leonardo - personally I like the approach of USB built into the main processor rather than a separate USB processor as on the Uno. It just seems more elegant.
    What would be some simple projects that only require wires, a breadboard, an Arduino, a button, and a LED?
  • simon.monk
    Well, a good really simple start is to take the blinking LED example and use an external LED on some bredboard in series with a 270Ω resistor in series with it. Then just work your way up, so maybe add a switch to turn the LED on and off, or 2 switches to increase and decrease the rate of flashing.
    I ca't really pass up the opportunity to plug my '30 Arduino Projects for the Evil Genius' book. This is a breadboard-based project book. It starts simple and gradually builds up to more complex projects. The book's website conatins pictures of all the completed projects as well as all the Arduino source code which you are free to take and do with what you will.
    http://www.adruinoevilgenius.com
    Does anyone make an opto isolator shield for rs232 communication on an arduino?
    how to use a non boot loaded atmega328 ic in arduino?
    i have a uno r3 and i want to program the 16u2 chip to act like a keyboard(HID).but i cant found the dfu mode so how can i make uno r3 dfu mode?
  • simon.monk
    You can use the ICSP header with a programmer like the USBTiny ISP to programe the ATMega directly, but if you are doing that, you may as well burn the bootloader using the programmer.
  • simon.monk
    Have you seen this thread about about turning an Uno into a USB HID?
    http://arduino.cc/forum/index.php?topic=99.0
    Alternatively,get a Leonardo
  • simon.monk
    I have not come across an isolating RS232 shield,
    but you could use an external one like this: http://www.usconverters.com/index.php?main_page=product_info&cPath=65&products_id=187
    with a regular RS232 shield like this one: http://www.cutedigi.com/arduino-shields/rs232-shield-for-arduino.html
