Arduino Forum Is this possable
  • Subscribers 417 subscribers
  • Views 766 views
Is this possable
I want to put some LED's on my sons drums so that they will light up when he hits them.  I could use a vibration sensor to turn on the lights or I was thinking.  Can I get a frequency sensor and have it read different sounds and have different lights come on when for the different instruments.  I found a place where I can get 5 meters of programable color lights.  Too bad I have to buy 20 rolls but I can deal with that.
Any suggestions anyone?
    Hi Dan,
    I don't know if you've finished your idea or not, but one thing I think you could try - piezo elements. Measuring frequencies might be a little complex, but with a piezo, I believe it outputs a different voltage depending on the force imposed on them. I couldn't say for certain, as I really only use piezos as tiny little speakers, but I think that would be a good starting point in this case. Best wishes!
    ~Gtr_Stitch
    If you go browsing around on adafruit.com's tutorials and forums, search for the Picolo code and FFT code(Fast Fourier Transform).  They make a small electret mic amp breakout which is input into an arduino.  The projects were to graph out the sound on LED matrix displays. I think you can use that code to do the frequency analysis instead of audio filtering with hardware/circuitry.  From there, you can drive any kind of light display you want.  Look into their NeoPixel products, they are extremely bright and a chain of them can be controlled by one pin.  They are individually addressable RGB LEDs with a built in current limiter chip.  You could just try to mount their Ampli-tie project in the drums. Only volume reactive but it would give the same visual effect.  Good luck.
    Piccolo http://learn.adafruit.com/piccolo/overview
    Yeah i agree with Richard .. A piezo elements your best luck ... Its realativly easy to use and it does output different voltage depending on the force put on them. let us know how it goes.
    A handful of piezos and opamps would be the simplest route. its kinda straightforward and would mostly just be a quick on/off. although...im toying around with an idea i had (inspired by your project). using an arduino, whenever a piezo is hit, the led will turn on, but fade out. an added effect. i must say, i get inspired easily, and ill post any results i come up with.
  • wmsundell
    wmsundell over 12 years ago in reply to e14 Contributor
    Yes, I agree.  A while ago I found a cute little project in Circuit Cellar mag, use a standard ruler, peizo speaker with housing removed, a small paper spring clamp with the folding handles removed, stick the peizo on ruler abt 2 in from one end and place clamp between peizo and a good rubber band from one end over other end. hook peizo to a small amp and play the ruler like a guitar.  It picked up frequencies really well.  So, I agree the peizo is a good choice.
