Arduino Forum trying to get an LED to come on for 3 seconds and come off without delay
  • Replies 29 replies
  • Subscribers 420 subscribers
  • Views 7465 views
  • arduino_code
hey guys i'm just trying to get an led to come on for 3 seconds and then comeoff, without using delay, i'm not understanding the millis function but i've tried a bit. kindly let me know what i'm doing wrong. thank you.
int count = 0;
long previousMillis = 0;
long interval = 3000;
void setup() {
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
void loop()
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    previousMillis = currentMillis;
     if (count <=1)
      digitalWrite(ledPin,HIGH);
    else
      digitalWrite(ledPin,LOW);
count ++;
  • billabott
    billabott over 13 years ago in reply to phoenixcomm +2
    Interesting insight Cris H. Unfortunately, your code does not plug into the 'Duino IDE too well. So, I took some time to create my own completely commented version which I now make available to everyone…
  • ntewinkel
    ntewinkel over 13 years ago in reply to e14 Contributor +1
    To have red and green alternating on, you basically copy the lines of code that turn the ledpin high and low and set opposite values for the other LED. ie, when you turn the red led on, at that time you…
    e14 Contributor over 13 years ago +1
    Thank you Navin and Nico I will definately try out the two versions! You guys are awesome and I will give you 50 cool points each! Seriously though, I just wish I could one day be as helpful as you two…
  • ntewinkel
    It looks like the led will only be on for 6 secs and then stays off.
    If you replace
      Count <= 1
    With
      count % 2 == 0
    Then it will be on for even counts and off for odd counts.
    (% is modulo, aka remainders of division)
    Hope that helps :)
    Ps maybe make previousMillis unsigned to match.
    Cheers,
    Nico
    e14 Contributor over 13 years ago in reply to ntewinkel
    Hi Nico, how would you write the code if you want to have a red led on for the even counts and a green led for the odd counts? I'm very new to programming and tried to use blink twice and switch the number on the led, then I tried to use switch case, then I tried to set a parameter where it will read the ouput and try to switch the led (like how a pushbutton would change the led from off to on described in Getting Started with Arduino by Massimo Banzi pgs. 55-64) but I have not had any progress. Am I wrong for thinking that programming would replace a switch? Well I thank the both of you for discussing this since it is somewhat similar to my problem and Navin gave me an idea to search for the Millis function!
    for the even it would be %2==0 and for off %2==1,, %2 will divide by 2 giving the remainder, therefore if its even you will get = 0 and odd will be =1. I am not an expert but i'd just use an if else statement, like mmm,
    if(count%2==0)
    digitalWrite(led,HIGH);
    else
    digitalWrite(led,LOW);
    and of course you'll have a counter.try your best not to use delay, if causes problems if you need to read inputs during the time it delays, since it literally pauses the entire program. Theres a timer library, search arduino timer library, it has oscillate and pulse and so on, not sure if thats what you're looking for.
    http://playground.arduino.cc/code/timer
  • ntewinkel
    ie, when you turn the red led on, at that time you would turn the green led off. And when you turn the red led off, you turn the green led on.
    if(count%2==0)
    digitalWrite(redLed,HIGH);
    digitalWrite(greenLed,LOW);
    else {
    digitalWrite(redLed,LOW);
    digitalWrite(greenLed,HIGH);
    You'd have to define and setup redLed and greenLed, of course, just like you did for ledpin.
    And you are correct - you can use programming instead of a physical switch, or instead of pretty much any input.
    Thank you Navin and Nico I will definately try out the two versions! You guys are awesome and I will give you 50 cool points each! image Seriously though, I just wish I could one day be as helpful as you two are, I am still trying to figure the whole IDE language and there are a plethora of books out there. I am super lost as to where to start. Bah!
  • billabott
    billabott over 13 years ago in reply to e14 Contributor
    [deleted]
    shabaz over 13 years ago in reply to billabott
    billabott wrote:
    Well, I can tell you and everyone else that the place to start is here: http://www.amazon.com/Programming-Language-2nd-Brian-Kernighan/dp/0131103628/ref=la_B000AQ1TNQ_1_1?ie=UTF8&qid=1364699822&sr=1-1
    It's such a great book. Ultra-concise and to the point. And although it is expensive compared to others, it holds it's value well and you can always sell it if you ever decide you don't need it.
  • ntewinkel
    ntewinkel over 13 years ago in reply to billabott
    Excellent references, billabott!
    Which reminds me...
    For those who don't want to spend money, there are also free resources available online:
    Like this C guide from Stanford: http://cslibrary.stanford.edu/101/EssentialC.pdf
    For free online courses from Stanford, with videos and assignments (full courses, but no credits given)...
    "C language and programming experience at the level of 106B": https://itunes.apple.com/ca/course/programming-abstractions/id495054099
    The prerequisite for that course is:   "Programming Methodology": https://itunes.apple.com/ca/course/programming-methodology/id495054181
    That course doesn't have prerequisites, "but does require considerable dedication and hard work."
    Cheers,
    -Nico
    e14 Contributor over 13 years ago in reply to billabott
    Hi there Billabott, I think one of the main reasons so many people have "ignored" the free documentation within the IDE. Or rather, have so much difficulty reading and understanding the free documentation that is provided, is the fact that the examples are somewhat scarce and just reading code can be quite confusing and gives many people the feeling of total isolation as to where to begin. I was somewhat apprehensive to ask a question anywhere on this site since most people seem to be extremely knowledgable and versed in the topics, and that they are somewhat complacent to how they begun reading lines and lines of code. They forgot how difficult it was to pick apart the code that they need vrs. the code that isn't needed therby wasting time and efficiency, not to mention brain power, to complete any project they embark on. Which tends to lead them to be crude and lacking a deft social touch. I don't mean to offend or be pessimistic but it is one thing if I asked a question on this site whilst holding any sort of degree or certification in C programming language and the likes, as opposed to a greenhorn just learning the language. I guess the best and most disarming analogy I can use is language in and of itself. Any language be it English, German, French, Japanese, or any of the languages used in the world today cannot just be looked upon by someone then spoken to the utmost fluency. To learn any language, first there must be a need to start somewhere and begin implementing a foundation from which to build upon. So you would start out leraning the alphabets, root words, pronunciation, verbs vrs. nouns, and how to form setences that is grammatically relevant to the native countries' language. So the same idea can be applied to C, no one can expect to see the lines of code and expect that there can be a authoritarian understanding of the language. It is human nature to delve deeper than just words and symbols to garner a deeper understanding of anything we are learning. Also, since I am a greenhorn I have used the reference site countless times trying to understand and put what I have read into logical reasoning as well as read three other books but to no avail in composing a code do to what I am looking for. I do thank you for your input but I don't appreciate someone assuming that I have done nothing to further my knowledge and try to hint at my classification as being lazy. There is a saying about assumptions but I feel that it is counter-intuitive to post on this site. Well, thank you all anyway for trying to lead me in the right direction, and I will look up this book so that I won't bog the site down with greenhorn questions. Thanks again for your time and consideration!
    -Jeder tut's auf seine Weise
  • billabott
    billabott over 13 years ago in reply to ntewinkel
    Just remember what Steve Ciarcia always said about designing in hardware verses software.  It is always a choice.
    One digital pin and 2 leds with current limiting ( I <= 20 mA ) resistors.  Polarity inverted for one of the LED legs and connected to the opposite rail.
    http://playground.arduino.cc/Main/ArduinoPinCurrentLimitations
