Arduino Forum Urgent Please help me please
  • Subscribers 418 subscribers
  • Views 421 views
i m trying to make coding with 8 sensor with different sensor IDS
SENSOR TYPE                             SENSOR ID
TEMP 1                                            1
TEMP 2                                             2
ULTARVOILET                                    3
PAR                                                  4
I NEED to read the serial port
analyze incoming byte
store sensor value according to each sensor id
and display it
please is there anyone who can help me in coding ..It would be greatest help
pleaseeeeeee
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago +2
    Harman Please don't cross POST or start another thread when your not getting what you need from the previous one, it becomes very confusing re: need help urgently.. I have already provided a fairly simple…
    mcb1 over 12 years ago in reply to Robert Peter Oakes +1
    Peter you're absolutely right. Harman you've asked for help to do your project, you've got help, but because you don't understand you post another request. I would consider that rather rude. Is this study…
    Try to store sensor values in any array so that you can access each value of array by the sensor id.
    char data[4];
    data[Sensor_Id - 1] = data_of_Sensor_ID
    Harman
    I have already provided a fairly simple framework for you to use and it would work for your requirements. any other solution will simply be a variation of this, even the feedback so kindly given by Saleem follows the same approach as my sample
    people will not want to do all this for you and I have already provided the basics to you. this additional thread is slightly more complex only in that you have called out more sensor IDs and I have shown you how to extend that too in the sample
    if your having difficulty with reading the actual sensors then tell us what sensors your using and show us the code you have so far tried, provide a connection (Schematic) diagram, we can then be in a better position to help
    if your so new to this that your having difficulty in reading a basic device then I would suggest starting with a simpler project (And there are plenty on the Arduino.cc site and others that will show you how to code, read simple sensors (All the ones you list are there) and how to output the values to a serial device.
    once you have mastered that, then move on to combining devises and extending to more complex systems
    Regards
    Peter
    Is this study that you're doing, related to this project.?
    is this project part of an assignment that you have to do.?
    If you truly want to learn then we can suggest some books and tutorials, but you need to invest time JUST like we did.
    I think we deserve some honest answers.
    mark
