Arduino Forum The Arduino Automated Sentry Turret (AAST)
  • Subscribers 417 subscribers
  • Views 572 views
  • helpme
  • electrical
I'm working on a turret that doesn't require a laptop for operation. This of course means that the turret won't be as advanced when it comes to targeting.
This turret will run on the Arduino Uno R3.
The reason why I'm not using a more advanced board is because I'm trying to focus on a more simplistic, inexpensive schematic.
Here's the list of things I'm using for this:
1x Arduino board
1x Ping Distance Detector (Used for left-to-right or right-to-left targeting)
1x PCB
1x Electric Airsoft Mechanism
1x Power N-Channel MOSFET
image1x Servo
??? (A section to fill in for stuff I probably forgot to put in this list)
Well, I haven't thought everything through. This is mostly being improvised, so I imagine that there's probably a TON to fix and add.
I'm just throwing this idea out there. Yes, I know that it's been done before, but I'd like some input. I'm a rookie, after all.
NOTE: Reminders or suggestions are labeled with: image
  • kidiccurus
    kidiccurus over 12 years ago
    You probably need a servo to move the turret left and right. Also, if you can persuade the other team to wear an infra red source then a wiimote sensor can give you x and y coordinates. See this instruct able for details m.instructables.com/id/Wii-Remote-IR-Camera-Hack/
    e14 Contributor over 12 years ago in reply to kidiccurus
    Oh god, that's right!
    I have a servo specifically for this, and I completely forgot to add it to this list!
    Thanks for the reminder!
    As for the Wii mote sensor idea, I'll look into it.
    Johnny.
  • kidiccurus
    kidiccurus over 12 years ago in reply to e14 Contributor
    Glad I could help.
