    • Avnet Boards Community
Arduino Forum arduino cctv
  • Subscribers 393 subscribers
  • Views 489 views
arduino cctv
hi
i interested on Arduino project
now i have an idea and need help
i plan to use arduino uno and TTL serial Jpeg camera with NTSC video to make a simple cctv with Bluetooth .
will it work? i do not know the circuit design and coding
really need a hand
thanks
  • dtsartsanis
    dtsartsanis over 10 years ago +2
    There is a tutorial from adafruit https://learn.adafruit.com/ttl-serial-camera/ where you can find all the informations you want. If you haven't already bought the parts i suggest Raspberry Pi for this…
  • clem57
    clem57 over 10 years ago in reply to Former Member +1
    Check voltage levels. Raspberry Pi are set at 3.3 volts and Arduino is 5 volts. Pick the one more compatible with your TTL's Clem
  • dtsartsanis
    There is a tutorial from adafruit https://learn.adafruit.com/ttl-serial-camera/ where you can find all the informations you want. If you haven't already bought the parts i suggest Raspberry Pi for this project. You can attach an old usb web camera and use motion. Or for more advanced project you can build an intruder detection Build an Intruder detector with Raspberry Pi and robomq.io
    Former Member over 10 years ago in reply to dtsartsanis
    Thank you so much for your link. It's so useful to me. The Arduino Project is so interesting. Please give me more information which about Arduino I should be learnt.
  • clem57
    Clem
  • volly
    volly over 9 years ago
    Hi clarat.,
    I believe this is exactly what you are looking for:
    https://www.adafruit.com/product/397
    Yunus
