Arduino Forum arduino not working
  • Replies 11 replies
  • Subscribers 403 subscribers
  • Views 996 views
arduino not working
ramyar
ramyar over 10 years ago
I tried to upload simple program in my freeduino uno,but it shows some java error in my desktop.when i tryed it with my friends laptop it worked.What will be the problem?
  • clem57
    clem57 over 10 years ago in reply to ramyar +1
    The Arduino IDE is broken not your code.
  • clem57
    Most likely reason (you did not post an error here) if I guessed is missing some Java classes. Go back to your instructions (you do follow them right?) and try to find the missing piece.
    Clem
    PS. element14jamie can you move to Arduino please. Thanks always
  • element14jamie
    element14jamie over 10 years ago
    Hello ramyar
    Welcome to the element14 Community, we hope you enjoy it! I will move this over to the Arduino area as it is a better fit thank you clem57
    Thank you,
    Jamie
  • ramyar
    ramyar over 10 years ago in reply to clem57
    no....just an example blink program too have this error?????
  • clem57
  • ramyar
    ok...I will try dowloading other version and let u known.thank you.
  • clem57
    Did you compare what versions of Java you have and what version your friends laptop was? I would uninstall the Java first and re install it. Did you post the errors here? This is the only way to fix a Java problem.
  • ramyar
    Hi...
    My problem still continues.
    My freeduino has the following error while i tryed to upload the example blink program
    Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
    Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
    Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xeb
    avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xeb
    Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
      This report would have more information with
      "Show verbose output during compilation"
      enabled in File > Preferences.
    The board works with my friends laptop and not in my desktop.
    And my .inf files are not installing.when i did it said that this file cant be installed in this method.
    My port option in tools is also disabled.
  • clem57
    Did you check out https://www.arduino.cc/en/Guide/Troubleshooting#upload. There is a good guide to find out why the board is not recognized on your computer. Do you see it under Devices in Windows? Do you have zone alarm?
    Clem
  • ramyar
    Yes.But nothing changed???
  • kidiccurus
    kidiccurus over 10 years ago in reply to ramyar
    Which version of the IDE are you using? There has recently been a fork. I recommend downloading the latest version from arduino.cc.
