    • Avnet Boards Community
Arduino Forum NRF24L01 Problem simplifying code
  • Replies 16 replies
  • Answers 3 answers
  • Subscribers 394 subscribers
  • Views 2313 views
  • nrf24l01
billpenner
billpenner over 10 years ago
I am using the NRF24 for receiver/transmitter on a link between a Uno and a Mega. the basis for the code is http://maniacbug.github.io/RF24 I have finally gotten the units working super. My project is to input a four digit code on the transmitter, send it to the receiver, which will echo back the data sent for accuracy check. Then the code will be displayed on a  three inch 7 segment display. My problem is: The code from the above is impossible for me to modify without breaking it. It seems that most of the work is done in the library RF24.h. The code is great for debugging and was very helpful for getting the NRF24s working. However, All my efforts to simplify the code to insert the data and extract it results in compiler errors. Does anyone have any help or a source for a more easily modified code for the NRF24?
Thanks to a bunch of great resource and to the dedication to us who are trying to learn.
Bill
    balearicdynamics over 10 years ago +2
    Hello Bill, Please can you put here the parts of code that you have in mind to break and simplify ? Maybe that there is some parts global that should be replaced in a different way. Thank you. Enrico
  • m.ratcliffe
    m.ratcliffe over 10 years ago +1
    The Blue link sends me back to this page, is the library you are using upto date? I got the following from: NRF24: NRF24 library for Arduino " This NRF24 library has now been superceded by the RadioHead…
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +1 suggested
    you may find the code here useful for reference, I used the NRF modules in last XMAS contest and provided all the code http://www.element14.com/community/groups/arduino/blog/2015/01/24/byob-party-15-news…
    0 balearicdynamics over 10 years ago in reply to billpenner
    Hi Bill,
    The following image shows how to catch the syntax highlighting in the editor image
    Enrico
  • billpenner
    0 billpenner over 10 years ago in reply to balearicdynamics
    I found how to use highlighting. Thanks for the advice.
    Bill,
    I suggest you that you set useful answer or correct answer to the post that was correct and helped you to solve the problem, instead of assumed answered the question.
    Enrico
  • billpenner
    Thanks a lot for all your suggestions, guys, I ended up using the code from maniacbug (RF24 network). I think I can modify this code to suit my needs.
    Github has a complete list of the commands and is well annotated.   I had a terrible time getting both the receiver and transmitter to work.
    There was an error at compiling relating to "Robot Control" in Arduino examples.
    The only way I found  to solve it was remove all files related to Arduino off the computer and re-installed them and all worked fine.
    Bill
  • billpenner
    0 billpenner over 10 years ago in reply to Robert Peter Oakes
    Help!  I'm afraid I spoke to soon. I have corrupted my Arduino by trying to install a rf24 library. Now nothing but compile errors. Can anyone tell me how to uninstall a library from Arduino?
    Bill
  • screamingtiger
    0 screamingtiger over 10 years ago in reply to billpenner
    Just delete it out of the libraries folder, and restart the IDE
