    • Avnet Boards Community
Arduino Forum ARDUINO bitvoicer ir sending
  • Subscribers 392 subscribers
  • Views 397 views
Former Member over 9 years ago
hello
i've got problem with my program
im using arduino mega. when i use bit voicer and irremote the ir led is blink so slow that tv cannot get right signal to turn off. when i use only irremote everything is ok. So i thinking that bitvoicer is slowing down irremote or maybe my program is wrong. i tried different timer in irremote library but it isn't work.
can enyone help me in this??
CODE
#include <IRremote.h>
#include <IRremoteInt.h>
IRsend irsend;
#include <BitVoicer11.h>
//właczanie bita
BitVoicerSerial bvSerial = BitVoicerSerial();
byte dataType = 4;
int OutPutPins[] = {10,12,11,8};
int pinCount = 4;
int wl = 0 ;
void setup() {
  Serial.begin(115200);
  for(int activePin =0; activePin <pinCount; activePin++){
    pinMode(OutPutPins[activePin],OUTPUT);
   pinMode(7, OUTPUT);
   pinMode(9, OUTPUT);
   digitalWrite(7,HIGH);// put your setup code here, to run once:
pinMode(5,INPUT_PULLUP);
void loop() {
void serialEvent()
dataType = bvSerial.getData();
//Changes the value of sampleTest if the received data was
//the start/stop sampling command
if (dataType == BV_COMMAND)
//Signals BitVoicer's Speech Recognition Engine to start
//listening to audio streams after the engineRunning status
//was received
if (dataType == BV_STATUS && bvSerial.engineRunning == true)
   bvSerial.startStopListening();
if (dataType == BV_INT)
  int pinNumber = bvSerial.intData;
digitalWrite(pinNumber, !digitalRead(pinNumber));
delay(50);
// tutaj wartości string czyli pisane
if(dataType == BV_STR)
  if (bvSerial.strData == "okej")
  digitalWrite(7,LOW);
  delay(500);
if (bvSerial.strData == "klas")
digitalWrite(9,HIGH);
delay(1);
if (bvSerial.strData == "klass")
digitalWrite(9,LOW);
if (bvSerial.strData == "komplet")
  irsend.sendNEC(0x5EA100FE, 32);
  delay(400);
  delay(500);
  irsend.sendNEC(0x20DF10EF, 32);
if (bvSerial.strData == "wiez")
  irsend.sendNEC(0x7E8154AB, 32);
if (bvSerial.strData == "tv")
if (bvSerial.strData == "klim");
  irsend.sendNEC(0x8F758A7, 32);
if (bvSerial.strData == "h1")
irsend.sendNEC(0x5EA1E21C,32);
if (bvSerial.strData == "h2")
irsend.sendNEC(0x5EA152AC, 32);
if (bvSerial.strData == "h3")
irsend.sendNEC(0x5EA1B24C,32);
if (bvSerial.strData == "h4")
irsend.sendNEC(0x5EA10AF4,32);
if (bvSerial.strData == "mut")
irsend.sendNEC(0x5EA138C7,32);
if (bvSerial.strData == "rad")
irsend.sendNEC(0x5EA1609,32);
if (bvSerial.strData == "en")
irsend.sendNEC(0x5EA1C03E,32);
if (bvSerial.strData == "pc")
irsend.sendNEC(0x5EA100FE,32);
if (bvSerial.strData == "opt")
irsend.sendNEC(0x5EA1D628,32);
delay(400);
irsend.sendNEC(0x5EA1B946,32);
delay(400);
irsend.sendNEC(0x5EA17B84,32);
delay(400);
irsend.sendNEC(0x5EA17986,32);
delay(400);
irsend.sendNEC(0x5EA155AA,32);
delay(400);
if (bvSerial.strData == "hd")
delay(400);
delay(400);
delay(400);
irsend.sendNEC(0x5EA1F906,32);
delay(400);
delay(400);
if (bvSerial.strData == "opc")
if (bvSerial.strData == "cof")
delay(200);
irsend.sendNEC(0x20DF14EB,32);
if (bvSerial.strData == "wyj")
irsend.sendNEC(0x20DFDA25,32);
if (bvSerial.strData == "set")
irsend.sendNEC(0x5EA121DE,32);
if (bvSerial.strData == "ok")
delay(100);
irsend.sendNEC(0x20DF22DD,32);
if (bvSerial.strData == "dir")
irsend.sendNEC(0x5EA1BB44,32);
if (bvSerial.strData == "pros")
irsend.sendNEC(0x5EA16A95,32);
if (bvSerial.strData == "cis")
irsend.sendNEC(0x5EA1D827,32);
if (bvSerial.strData == "dol")
irsend.sendNEC(0x5EA139C6,32);
delay(100);
irsend.sendNEC(0x20DF827D,32);
if (bvSerial.strData == "gora")
delay(100);
irsend.sendNEC(0x20DF02FD,32);
if (bvSerial.strData == "pr")
delay(100);
irsend.sendNEC(0x20DF609F,32);
if (bvSerial.strData == "lew")
delay(100);
irsend.sendNEC(0x20DFE01F,32);
if (bvSerial.strData == "inp")
irsend.sendNEC(0x20DFD02F,32);
if (bvSerial.strData == "tel")
delay(100);
if (bvSerial.strData == "jeden")
delay(100);
if (bvSerial.strData == "dwujka")
irsend.sendNEC(0x20DF48B7,32);
delay(100);
if (bvSerial.strData == "trujka")
irsend.sendNEC(0x20DFC837,32);
delay(100);
if (bvSerial.strData == "polsat")
irsend.sendNEC(0x20DF28D7,32);
delay(100);
if (bvSerial.strData == "tvn")
irsend.sendNEC(0x20DFA85,32);
delay(100);
if (bvSerial.strData == "next")
irsend.sendNEC(0x20DF00FF,32);
if (bvSerial.strData == "prev")
irsend.sendNEC(0x20DF807F,32);
    shabaz over 9 years ago +1 suggested
    Your code is hard to follow, because it is missing indentation. You can edit your post, and use the syntax highlighting tool in the editor on this website (Click on the icon that looks like '>>' and navigate…
  • Robert Peter Oakes
    Robert Peter Oakes over 9 years ago +1 verified
    Asside from the comments from Shabaz which I totally agree with, indentation and neat readable code is essential in helping with debuging there is one obvious thing wrong with your code if (bvSerial.strData…
    0 shabaz over 9 years ago
    You can edit your post, and use the syntax highlighting tool in the editor on this website (Click on the icon that looks like '>>' and navigate down to
    Syntax Highlighting.
    Then you can show code that looks like this (example), with indentation - much easier to follow and troubleshoot/debug as you can see:
    #include stdio.h
    int
    main(void)
     // code
     return(0);
    Also, as a general hint, to get you moving forward, I'd advise cutting down your code until you are only performing actions for one command/IR signal.
    If you can get that to work, then you can scale to the larger program.
    If you can't get that smaller program to work, can you paste it with indentations so we can follow it?
    0 Robert Peter Oakes over 9 years ago
    if (bvSerial.strData == "dol") irsend.sendNEC(0x5EA139C6,32);
    delay(100);
    if (bvSerial.strData == "gora") irsend.sendNEC(0x5EA1B946,32);
    delay(100);
    you have no "{ }" arround your if code so only the first command after the if will be executed if the "IF" is true and everthing after that will always be executed, this includes ALL your delays and ALL the additional send commands
    to contain a sequence of code to only work if the "IF" is true / to be run then it is essential you encapsulate the code with the curly braces
    regards
    Peter
    0 shabaz over 9 years ago in reply to Robert Peter Oakes
    Agree, it is bad structure.
    There are only about 35 commands in C misiek271 so good to scan through them( before you begin any coding project if you're a beginner),
    so that you can see what tools (which is what these commands are) are best used for the coding sub-task that you are trying to achieve.
    If you use a nail to solve everything, your code gets long and difficult to follow, and hence the errors.
    There are more elegant structures, and they often (not always) leads to more readable code and less errors and save you time.
    Half a day looking through the 35 or so commands and their structure will speed you up and save you days/weeks/months of coding and troubleshooting time.
    0 Former Member over 9 years ago in reply to shabaz
    yes im newbie. And ill check this command. Problem is solved. and everything work's fine because of You. So thanks again.
