Arduino Forum Stepper motor wiring help(and a few other small questions from an instructable)
  • Replies 55 replies
  • Subscribers 420 subscribers
  • Views 6996 views
  • wiring
  • steppers
gub11
gub11 over 10 years ago
This instructable really interested me, Frameless Laser Harp - 4 , but i've never worked with steppers before.  the stepper i got has 4 wires, but the stepper in the instructable has 6.  on page 2 there is a wiring guide, but that wasn't very helpful to me, i didn't really understand what i'm supposed to do with the wires.  This is the stepper i have, https://www.sparkfun.com/products/10551?gclid=Cj0KEQiApruyBRCFqoDu1pbk9rkBEiQAF8EFdVmEBorGt6koPmFkaibEpRmZ94Z6r8BWhmTqAL… .  Any ideas?
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to gub11 +2 suggested
    reverse... to change direction lol now more seriously... then you wire up the stepper motor, if it is not going in the direction you expect for the command your giving then you can change the code or simply…
    Robert Peter Oakes over 10 years ago +1
    Here is an excelent resource regarding steppers and how they work http://www.geckodrive.com/support.html I found this to be very helpfull in setting up my CNC project your stepper is a classic 4 wire …
    Robert Peter Oakes over 10 years ago in reply to gub11 +1
    All Grounds (0V) should go together, the ground of the 12V, the 5V etc all are connected together at a common point the 5V goes to all those pins because it is 5V logic input to the chip and those pins…
  • gub11
    0 gub11 over 10 years ago in reply to jc2048
    jc2048
    That's really helpful, I looked for heatsinking on ebay and element14's store, but couldn't find anything, coudl you link me some cheap heatsinking (i live in the US).
    Robert Peter Oakes
    I finally got the stepper driver and I put it all together, but I am having a few issues that I don't really know how to diagnose.  I did some trial and error, but that could only help so much.  First of all, the laser doesn't turn on, second the stepper has an odd pattern of off and on, when i think it's supposed to stay on at a constant speed.  I'll take a video of that and show a diagram of how I have it wired up when I get home.
    Gabe
    0 Robert Peter Oakes over 10 years ago in reply to gub11
    looking forward to the video so I can help diagnose the issue
    Can you also post the code you are using and the wiring sketch you ended up with when you post the video
    Peter
  • jc2048
    0 jc2048 over 10 years ago in reply to gub11
    Sorry, I'm not in the US.
    This is a glue-on type:
    http://www.newark.com/fischer-elektronik/ick-14-16-l/heat-sink/dp/35M3896
    This is a clip-on type:
    http://www.newark.com/aavid-thermalloy/580200b00000g/heat-sink/dp/18M8201
    The clip-on type is more expensive, but you can reuse it.
    Whether it makes sense for you to buy from Newark I don't know.
    TI really intended you to use the pcb, either by passing the heat down to a ground plane on a multi-layer board, or by having an area of copper next to the chip on either side on a two-layer board. The package resin doesn't conduct heat very well and they've engineered the chip to get as much of the heat down the ground pins as possible so although you'd certainly be helping with a heatsink on the top it's not as good value as taking the heat from those pins if you can.
  • gub11
    0 gub11 over 10 years ago in reply to Robert Peter Oakes
    Robert Peter Oakes
    Diagram is below and here is the link to the youtube video.  https://youtu.be/T0Lmc4enkbg
    diagram:  Imgur: The most awesome images on the Internet
    Code:
    int LaserState = LOW;                    // The variable that stores the state of the laser beam.
    int sensor = 8 ;                         // Change this value to calibrate your harp's sensor
    int delaylaser = 5;                     // If you increase this, the laser will be brighter, but the harp will be less fluid
    int delaymotor = 3;                     // This variable affects the speed, and fluidity of the harp.
    int LaserPin =  7;                       // Tell the arduino that the laser is on pin 7
    int motorPin1 = 8;                      //Use these names for the pin numbers.
    int motorPin2 = 9;
    int motorPin3 = 10;
    int motorPin4 = 11;
    int note9 = 0x61;
    int note8 = 0x63;
    int note7 = 0x64;
    int note6 = 0x66;
    int note5 = 0x68;
    int note4 = 0x70;
    int note3 = 0x71;
    int note2 = 0x40;
    int note1 = 0x47;
    int a, b, c, d, e, f, g, h, i = 0;       // Iniating the note status markers.
    void setup()
      pinMode(8, OUTPUT);                    // Setup for the motor.
      pinMode(9, OUTPUT);
      pinMode(10, OUTPUT);
      pinMode(11, OUTPUT);
      pinMode(LaserPin, OUTPUT);            // Setup for laser.
      pinMode(13, OUTPUT);                 // Setup for status led.
      Serial.begin(31250);                 //  Start a serial communication channel for MIDI
    void noteOn(int cmd, int pitch, int velocity)     // Function to play the notes
      Serial.write(cmd);
      Serial.write(pitch);
      Serial.write(velocity);
    void loop()
      digitalWrite(LaserPin, HIGH);               // Turn on the laser for the 1st beam.
      delay(delaylaser);
      if ( (analogRead(0) > sensor ) && (a == 0) ) // If the sensor gets a signal, and the not is not playing:
      digitalWrite(13, HIGH);       // Switch on status led.
      noteOn(0x90, note1, 0x7F);    // Play note 1
      a++;                          // Change the status variable to one.
      else if(analogRead(0) < sensor )             // If the sensor does not get a signal:
      digitalWrite(13, LOW);         // Switch off the status led.
      noteOn(0x90, note1, 0x00);     // Stop playing note 1.
      a = 0;                         // Change the status variable to zero.
      digitalWrite(LaserPin, LOW);                // Turn off the Laser.
      digitalWrite(motorPin1, HIGH);             // Move the motor to create the second beam.( One step forward)
      digitalWrite(motorPin2, LOW);
      digitalWrite(motorPin3, LOW);
      digitalWrite(motorPin4, LOW);
      delay(delaymotor);                          // Small pause
      digitalWrite(LaserPin, HIGH);              // Turn on the laser for the 2nd beam.
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (b == 0) ) // If the sensor gets a signal, and the not is not playing:
      noteOn(0x90, note2, 0x7F);           // Play note 2
      b++;                                 // Change the status variable to one.
      noteOn(0x90, note2, 0x00);      // Stop playing note 2.
      b = 0;                          // Change the status variable to zero.
      digitalWrite(motorPin1, LOW);              // Move the motor to create the second beam.( One step forward)
      digitalWrite(motorPin2, HIGH);
      digitalWrite(LaserPin, HIGH);             // Turn on the laser for the 3rd beam.
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (c == 0) ) // If the sensor gets a signal, and the not is not playing:
      noteOn(0x90, note3, 0x7F);    // Play note 3
      c++;                          // Change the status variable to one.
      noteOn(0x90, note3, 0x00);    // Stop playing note 2.
      c = 0;                        // Change the status variable to zero.
      digitalWrite(motorPin1, LOW);               // Move the motor to create the third beam.( One step forward)
      digitalWrite(motorPin3, HIGH);
      // Contiue in the same way for the rest of the code.
      digitalWrite(LaserPin, HIGH);               //This is beam 4
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (d == 0) )
      noteOn(0x90, note4, 0x7F);
      d++;
      noteOn(0x90, note4, 0x00);
      d = 0;
      digitalWrite(motorPin4, HIGH);
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);                  //This is beam 5
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (e == 0) )
      noteOn(0x90, note5, 0x7F);
      e++;
      noteOn(0x90, note5, 0x00);
      e = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);                  //This is beam 6
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (f == 0) )
      noteOn(0x90, note6, 0x7F);
      f++;
      noteOn(0x90, note6, 0x00);
      f = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);                  //This is beam 7
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (g == 0) )
      noteOn(0x90, note7, 0x7F);
      g++;
      noteOn(0x90, note7, 0x00);
      g = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);                   //This is beam 8
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (h == 0) )
      noteOn(0x90, note8, 0x7F);
      h++;
      noteOn(0x90, note8, 0x00);
      h = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);    //This is beam 9
      delay(delaylaser);
      if( (analogRead(0) > sensor ) && (i == 0) )
      noteOn(0x90, note9, 0x7F);
      i++;
      noteOn(0x90, note9, 0x00);
      i = 0;
      delay(delaymotor);
      delay(delaylaser);
      h++;
      h = 0;
      delay(delaymotor);
      delay(delaylaser);
      g++;
      g = 0;
      delay(delaymotor);
      delay(delaylaser);
      f++;
      f = 0;
      delay(delaymotor);
      delay(delaylaser);
      e++;
      e = 0;
      delay(delaymotor);
      delay(delaylaser);
      d++;
      d = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);    //This is beam 3
      delay(delaylaser);
      c++;
      c = 0;
      delay(delaymotor);
      digitalWrite(LaserPin, HIGH);    //This is beam 2
      delay(delaylaser);
      b++;
      b = 0;
      delay(delaymotor);
    // Back to top.
    0 Robert Peter Oakes over 10 years ago in reply to jc2048
    Thats the kind I was refering too, thanks for posting the link
    Based on this diagram it looks like none of your grounds are connected together (the 0V lines of both supplies and the arduino and the chip should all be connected together, see the green lines
    based on what I am seeing this should fix the electrical by having all devices and chips connected together via the ground (0V) line
    the reason the Lazer is not turning on is that there is no ground path for the transistor to return the base current to the arduino, thats why the first green line to be added from the 9V battery
    the possible reason the stepper is not working properly is that while the 12V supply has a return path to the battery, and the arduino is connected to a pin of the chip, the two grounds are not connected and therefor maybe excessive current through the chip or something similar therefor the second green added
  • gub11
    Robert Peter Oakes
    I am trying it right now, but I don't understand what that would change
  • gub11
    Robert Peter Oakes
    After doing exactley what you did in the diagram, the laser works now(YAY), but now i just need the stepper to stop being weird.  Now when i turn it on the stepper moves, stops for like half a second, then moves again
    Glad were getting there, I dont have the chip you have but tomorow I will look at the sketch for you, its 2:30AM here so im off to bed image
    Can you take a really good picture of your breadboard and post it, as high a resolution as you can so I can see all your connections
    I know you posted the fritzing diagram but I need to see what you did vs what you should have done image
  • gub11
    Ok, here it is, but BTW, the fritzing has all of the exact connections i have if u need more of a reference.  I took 7 pictures just in case any connections were unclear, let me know if you have any questions about them.
    they are 5312x2988 (that should suffice image)
