Arduino Forum Parsing integer strings?
  • Replies 19 replies
  • Answers 2 answers
  • Subscribers 407 subscribers
  • Views 2694 views
  • serial_communications
  • potentiometers
  • parsing
  • boolean
scorpion
scorpion over 10 years ago
I need help with parsing a string of integers sent from another Arduino. The values will be like this 1, 0, 1234, 1234,
1 is a Boolean
0 is a Boolean
1234 are pot values
I would like for it to go to variables
Vpot is first pot value
Hpot is second pot value
C is first Boolean
Z is second Boolean
Ben Bonen
    shabaz over 10 years ago +1
    sscanf is your friend, probably supported by Arduino (I don't use Arduino). Reddit on the topic however is here. https://www.reddit.com/r/arduino/comments/pznnj/using_sscanf_with_arduino/
  • gadget.iom
    gadget.iom over 10 years ago +1
    The Serial.readStringUntil command may help you if you are receiving the data through the serial port. Something like this might work: void loop(){ String C = Serial.readStringUntil(',').toInt(); Serial…
  • clem57
    clem57 over 10 years ago +1
    One way is using indexOf( ) like in http://stackoverflow.com/questions/11068450/arduino-c-language-parsing-string-with-delimiter-input-through-serial-interf… Then easy to convert to known values. Suggest…
  • scorpion
    0 scorpion over 10 years ago in reply to gadget.iom
    @Paul Ellison
    That is true, but that number (1234) was just and example and I am not sure what the actual analog range of a pot is.
    So, what if I mapped the input value to a range of 0 to 999 and used that?
    Would that work?
    Ben
  • Robert Peter Oakes
    0 Robert Peter Oakes over 10 years ago
    This topic is fully covered in a seriese I posted a while back
    Fast Track to Arduino Programming
    Lesson 2 and 3 are the ones most relevent to your issue
    they use a C command strtok that allows parsing of strings using a provided token or tokens and is very powerful and perfect for this kind of scenario
    Enjoy
    0 Robert Peter Oakes over 10 years ago in reply to scorpion
    See below for my other response using strtok
    strtok will not care how big the number is, it looks for the delimeters and effectivly splits up the string based on them
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to scorpion
    The code I've provided below might just work regardless of with the pot value runs into 0, 1, 2, 3 or 4 digits. Would you mind giving it a try.
    Would be interested to know if it works image
  • neilk
    0 neilk over 10 years ago in reply to gadget.iom
    Paul, did you forget to include the code? I can't see it.
    Neil
  • gadget.iom
    0 gadget.iom over 10 years ago in reply to neilk
    Hi neilk
    It was posted earlier. Can be found by scrolling down to here:
    Re: Parsing integer strings?
  • neilk
    Hi gadget.iom
    Thanks Paul, got it now.
    Neil
  • gadget.iom
    You're welcome. Glad it helps somebody. image
  • scorpion
    UPDATE:
    Thank you for all of your help! image
    I forgot to mention that I was using this with a wireless transmitter to control an ESC, so I will just transmit the ESC control code through it.
    Ben
