Arduino Forum Measure power generated by a solar panel using arduino
  • Subscribers 418 subscribers
  • Views 4543 views
  • solar power
  • power_measurement
  • arduino sensor
  • solar
vish
vish over 10 years ago
I want to do a project where I have to measure the power generated by a solar panel using an arduino. My solar panel is of rating 6V 100mA, but I want to have a real time view of how much power is generated.
What is the best way to go about this?
With Thanks,
Vishnu Raj
  • ipv1
    ipv1 over 10 years ago +2
    You need to log the Voltage across the Panel and also the current being drawn. P=V x I Google 'Labview solar panel' and you will get a truck load of stuff for measuring and monitoring solar panel. In general…
  • clem57
    clem57 over 10 years ago +2 verified
    Here is a good example with explanations of terminology.Take a look at ARDUINO ENERGY METER . Cheers, Clem
  • milkovici
    milkovici over 4 years ago +2
    To measure or increase solar energy production, you need to increase the amount of solar energy hitting the solar panels. The maximum amount of solar energy hits the solar panels if the angle of incidence…
  • ipv1
    0 ipv1 over 10 years ago
    Google 'Labview solar panel' and you will get a truck load of stuff for measuring and monitoring solar panel. In general you will need a basic opamp and ADC circuit for the Voltage and a current sense amplifier and ADC for the current.
    Lemme know if you need the details.
  • clem57
    0 clem57 over 10 years ago
    Cheers,
    Clem
  • clem57
    0 clem57 over 10 years ago in reply to clem57
    How did that work out? Please mark correct to help me. Thanks
  • cerzasd
    0 cerzasd over 4 years ago
    How would you measure the power generated by a solar panel?
  • milkovici
    0 milkovici over 4 years ago
    To measure or increase solar energy production, you need to increase the amount of solar energy hitting the solar panels. The maximum amount of solar energy hits the solar panels if the angle of incidence of the rays is 90 degrees. Thus, the task of the automatic regulation system is to change the position of the solar panels so that the angle of incidence of the sun's rays is 90 degrees. In my DIY off-grid solar system to power my home, which I purchased from www.dragonsbreathsolar.co.uk/.../diy-off-.., I also need to measure the power generated by the solar panel. My friends advised me to do this with an Arduino.
  • robogary
    0 robogary over 4 years ago in reply to cerzasd
    Measure the volts and amps at the panel terminals.
    • Vote Up -1 Vote Down
