Arduino Forum How to learn more C for the Arduino?
  • Subscribers 418 subscribers
  • Views 779 views
  • learn
  • learn to code
  • c
  • java
I'll start this by saying that I already have some programming experience. I took Comp Sci I and AP Comp Sci in school, so I'm familiar with the basics of Java.
I'm looking to know more of C, specifically how it applies to the Arduino. I'm not the most familiar with pointers, except that they point to locations of memory, and that in Java they're called references and they're hidden from you.
I will admit that I don't exactly know how strings in C work, other that in Java they're objects and you can 'walk' them as an array.
I'm looking for more of a hard book that I could read and learn instead of Codeacademy.
  • clem57
    clem57 over 10 years ago in reply to tonyboubady +1
    If you look into the process, Arduino handles C/C++. https://www.quora.com/What-language-does-Arduino-use-C-C++-or-processing?share=1 I would suggest to Jacob Morgan , to learn IDE as most would and then…
  • organtin
    0 organtin over 10 years ago
    Hi.
    I admit the answer is somewhat biased :-), but I wrote, together with three colleagues, a book on scientific programming to teach C to science students. The book is called "Scientific Programming" and has been published by World Scientific. On my website, under Publications, there is a free addendum on Arduino.
    Certainly the book is not so cheap :-(, but we cannot have any influence on that.
    I suggest it just because it was designed especially having in mind the need for a scientist to understand what happen inside a computer. While all C manuals starts with "Hello World" our first program convert a temperature from Celsius to Fahrenheit and vice versa. All the examples are meaningful and most readers appreciate it.
    In the remote case you want to give a chance to it (maybe you can find it in some public library) just let me know if you found it useful :-)
  • clem57
    0 clem57 over 10 years ago
    For a book, check out Summary « C programming for Arduino . But if you feel you have strong programming skills in Java for example, start with https://www.arduino.cc/en/Hacking/BuildProcess . from there try https://www.arduino.cc/en/Guide/HomePage  & lastly this
    https://www.arduino.cc/en/Tutorial/HomePage .
    Clem
    PS this is a great reference Arduino Playground - Tutorial List
  • tonyboubady
    0 tonyboubady over 10 years ago
    First of all, Java is not equal to C (!=), Java is Object Oriented Programming and C is a structural programming language...
    You must have learned structural programming before you go for Object Oriented, but now you are doing other way around. Structural programming is a sequential coding practice, like it's executing line by line, your coding logic must have a flow...but in OOP concept it's all about creating objects, inherit from base class, delegate functions etc... there will be no flow in OOP...it's like lego pieces...
    Make a mind set that it's not like a OOP... create you coding logic based on a flow line by line concept...
    Look for any C embedded books and learn, that will be the start for you...
  • clem57
    0 clem57 over 10 years ago in reply to tonyboubady
    I would suggest to Jacob Morgan, to learn IDE as most would and then go to town on C++ as he wishes. The libraries like wiring does use objects.
    Clem
  • tonyboubady
    0 tonyboubady over 10 years ago in reply to clem57
    Nice info for me too, thanks...
