Arduino Forum How can interface a 6 pin toggle switch to arduino Uno?
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 837 views
manisha17
manisha17 over 9 years ago
I am facing difficulty to connect toggle switch to arduino.So plz help me regarding this...
    jw0752 over 9 years ago +1 suggested
    Hi Manisha, Without more information there is no answer to your question. We can't even tell if you are having trouble mechanically with the connections or if you mean you do not know which pins to make…
    0 jw0752 over 9 years ago
    Hi Manisha,
    Without more information there is no answer to your question. We can't even tell if you are having trouble mechanically with the connections or if you mean you do not know which pins to make the connections to. Furthermore with out a plan and a purpose there is no reason to hook a DPDT toggle switch up to an Arduino. Give us more information and we will see of we can help.
  • manisha17
    0 manisha17 over 9 years ago in reply to jw0752
    Hello Sir,
    thanks for reply.....
    I want to interface toggle switch with arduino because in my project,I want to use gsm and gps with that toggle switch...means if i pressed toggle switch then a message will send to the predefined number and location will also traced.
    That's why I want to know interfacing of pins and code....
    manisha
  • fvan
    0 fvan over 9 years ago in reply to manisha17
    Do you have a picture or model number for the toggle switch? Otherwise it's not possible to provide correct information.
