Arduino Forum Please help suggest a electronic pushbutton swich replacement
  • Subscribers 401 subscribers
  • Views 495 views
  • ardouino
  • circuitdesign
  • attiny
  • attiny85
  • circut
eatumup
eatumup over 9 years ago
So a little background on what I am doing. I have a remote control that I would like to adapt to be switchable by an attiny flashed to arduino. I have both the attin84 and the 85 chips to select from. The remote control utilized a 12volt L1028 battery. The remote uses a surface mount tactile switch on the negative battery terminal.
I'm very new and am still learning what im doing. My first thought would be to use a 12v relay with 5 volt coil in place of the switch. But I am not sure that's the best way to go about this. Ultimately I would like to replace that tactile switch with something else that the attiny can trigger.
any suggestions on that something else?
Thank you
    dougw over 9 years ago +2 suggested
    You can drive a BSS138 FET directly from your MCU, but it is a surface mount part. If you want a part with through-hole pins try a 2N7000.
    dougw over 9 years ago in reply to eatumup +1 verified
    The switch you described would be connected between an internal pull-up resistor and ground. Connect the ground pin of the switch to the source (S) pin of the FET. Connect the other pin of the switch to…
  • eatumup
    eatumup over 9 years ago in reply to dougw +1
    Thank you very much for taking the time to help this newbie learn to design.
    0 dougw over 9 years ago
  • eatumup
    0 eatumup over 9 years ago in reply to dougw
    Since your suggestion I have been looking into transistors to try and wrap my head around them better. Ive only ever used them as part of a pre-written schematic. So im still learning to apply them. Thank you for your suggestion. I think it will be the way to easiest accomplish my goal.
    0 dougw over 9 years ago in reply to eatumup
    Connect the other pin of the switch to the drain (D) pin of the FET.
    Connect the gate (G) pin of the FET to the ATTINY output pin.
    When the ATTINY output pin goes high, the transistor turns on, making it look like the switch was pushed.
  • eatumup
