Arduino Forum What do mean by arrays?
  • Replies 9 replies
  • Subscribers 403 subscribers
  • Views 993 views
  • processing
  • arudino
topaz
topaz over 9 years ago
Over 5 days this question remained in my mind "What do mean by arrays"?
    DAB over 9 years ago +1
    A simple way to think about Array's is to look at an old record Juke box. You have a series of records or CD's lined up along the selection cabinet. When you enter the code for the CD you want, the mechanism…
  • D_Hersey
    D_Hersey over 9 years ago in reply to DAB +1
    I certainly wasn't trying to correct you, DAB. Just trying to throw in a fun fact. Any linear ordering of data for which we can perform comparison operations on the indices, so long as they are unique…
    DAB over 9 years ago in reply to D_Hersey +1
    No problem, I was just making sure that we answered the question of an obvious newbie with simple explanations. There is plenty of time to bring them over to the dark side later. DAB
  • beacon_dave
    0 beacon_dave over 9 years ago
    "An array is a series of memory locations – or ‘boxes’ – each of which holds a single item of data, but with each box sharing the same name. All data in an array must be of the same data type."
    BBC Bitesize - KS3 Computer Science - Arrays and lists - Revision 1
  • jgerred
    0 jgerred over 9 years ago
    Basically an array is a variable that holds multiple values.  For instance a single variable called "a" can hold a single value as in "a=1".  Turning that variable into an array makes it sort of like a list of values that are accessible via that same variable name but with an index added (most arrays are zero indexed), for example a="9 5 6 3 2" gives us a[0]=9, a[1]=5, a[2]=6, a[3]=3, a[4]=2.  You can also assign a value to an array index directly, for example a[4]=5 would change the value in the slot a[4] from a 2 to a 5.  How you initialize and populate an array variable varies depending on which language you are using, but they all behave basically the same way.
    0 DAB over 9 years ago
    When you enter the code for the CD you want, the mechanism goes to that location and loads up the CD.
    An array in computer terms is a list of numbers, records, directories, etc.
    Each item in the array is accessed by an index number.
    Since each item is in sequence, the index is an integer number so that you can select a value from 0 to n.  Note some languages use 1 to n.
    You can check the entire list by setting up a FOR loop that retrieves each array item sequentially to compare values or data to the data or item of interest, such as the correct CD.
    So an Array is just a list that the programmer can establish to catalog just about anything.
  • D_Hersey
    0 D_Hersey over 9 years ago
    You can have arrays of arrays
  • D_Hersey
    Arrays don't have to be indexed by integers. . .
    https://en.wikipedia.org/wiki/Associative_array
    0 DAB over 9 years ago in reply to D_Hersey
    True, but in general they are discrete identification indexed.
    I always try to keep it simple.
  • D_Hersey
    0 D_Hersey over 9 years ago in reply to DAB
    I certainly wasn't trying to correct you, DAB.  Just trying to throw in a fun fact.  Any linear ordering of data for which we can perform comparison operations on the indices, so long as they are unique, probably qualifies as an array.  Tough to teach this stuff because the answers for a beginner are often different from the ones we give to a more advanced student.
    There is plenty of time to bring them over to the dark side later. image
  • teprojects1
    0 teprojects1 over 8 years ago
    arrays are the combination of memory block which helps you to store data contiguously, it will very helpful in the case of iterative data interaction. By using array you can easily operate any Arduino Projects or other engineering projects in which you have to control system by using programming.
