    • Avnet Boards Community
Arduino Forum Which shield for my project ?
  • Subscribers 393 subscribers
  • Views 315 views
anuti
anuti over 8 years ago
Hi Element14 community !
I'm novice in the arduino, so I wanted to start a project with an UNO.
I would like to control some servos (12 exactly) with a ps3 controller, but I need your help because I don't know how to start...
I just have found some shields:
_An USB host shield but I don't know if I could plug 12 analog servos.
Platine USB Hôte pour Arduino - RobotShop
_Or An USB host shield less expensive
http://www.ebay.com/itm/USB-Host-Shield-Support-Google-Android-ADK-UNO-MEGA-Duemilanove-2560-Arduino-/310569283009?hash=item484f5f2dc1:g:CkMAAOSw8gVX~1wT
And a servos shield (but I'm afraid it is not compatible)
https://www.adafruit.com/product/1411
_Even this stuff
ServoShock - Home
But you can tell me other way to make it, of course.
Thank you in advance for your help !
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago +2 suggested
    The Adafruit one would work fine, it is designed for the Arduino. It sounds a bit like your trying to run before you can walk if you get the saying... I would suggest you try to simply get some code working…
  • anuti
    anuti over 8 years ago +1
    Thank you Peter Oakes for your answer, Well I'll take a look again on several forums, but I've never used any shield so It's quite new for me. I have already "googled" the problem (youtube etc...) but…
    0 mcb1 over 8 years ago
    Do you have any that are stocked on by element14/Newark.?
    0 Robert Peter Oakes over 8 years ago
    I would suggest you try to simply get some code working for the servos first, if you go with the adafruit board, they already have libraries etc on the product page for you to use, along with sample code. Understand this first then move on
    next get to grips with using a PS3 controller with an arduino (NO SERVOS in this one), there are plenty of examples on the Arduino site and many other places, so again you're not having to re-invent anything, just figure out how it works.
    When you understand how each is working then try to combine them together, if or when you get stuck, post your code here and we will help you out to move forward.
    We see this all the time and I apologize if I am grouping you with others but many newcomers want to get to the end game before they have learned the basics, if the members here simply provide the answer without you having tried first, were not helping you, were just doing it for you. We can't teach you to program (Well we could but that would take a while and not what this site if for), we do expect the member to have at least googled the problem and try a few things before posting the question, in your case, most of the answers are already available. please have a look, try them out and try to merge them. I don't know your skill with programming so based on the question I am assuming a beginner.
    I look forward to what you come up with and helping you move it forward.
  • anuti
    0 anuti over 8 years ago
    I have already "googled"  the problem (youtube etc...) but by posting it, I wanted to be sure in fact.
    I completely understand your point of view, I am going to try to apply your advice
    ps: thank you mcb1 but I'll test with the adafruit shield.
