Arduino Forum Using 40 low frequency Mics.
  • Replies 21 replies
  • Answers 12 answers
  • Subscribers 418 subscribers
  • Views 3777 views
noblemaster
noblemaster over 9 years ago
I am working on a device that takes input from 40 microphones and send data to PC via Arduino.
I want to use low frequency microphones (5Hz onwards) with around 200-250Hz sampling for each mic.
For this purpose, my preliminary design is like this...
    40 Mics --> 40 PreAmp circuits --> Mux Shield II --> Arduino DUE --> PC
Please suggest me suitable commercial available preAmp circuits and any suggestion on the design is most welcome.
Thanks.
    dougw over 9 years ago in reply to noblemaster +2 suggested
    Your answer suggests you are willing to spend over $1000 per channel to get the best possible. If that is not true, the description needs to be more complete in order to get a helpful answer.
    michaelkellett over 9 years ago in reply to noblemaster +2 suggested
    To measure at up to 100Hz you need to sample each microphone at 500Hz or faster. For each microphone you will need a a buffer amplifier as shown on the Invensys data sheet and an anti-aliasing low pass…
  • rachaelp
    rachaelp over 9 years ago in reply to DAB +2 suggested
    DAB is right, the USB on the Arduino is serial over USB, i.e. it just shows up as a serial port on the PC and you'll probably be maxed out at 115200 baud (I may be wrong here but you should look into it…
    0 dougw over 9 years ago
    What level of fidelity / accuracy do you need?
  • noblemaster
    0 noblemaster over 9 years ago in reply to dougw
    As much as possible.
  • rachaelp
    0 rachaelp over 9 years ago
    Most commercial mic pre circuits I believe have DC blocking caps so they are suitable for use with phantom powered mics. As such they have an inherent roll off at low frequencies so you'll be struggling to get a decent level through most sensibly priced ones at 5Hz. There are some exceedingly expensive options such as http://www.studiocare.com/summit-ecs-410-everest-channel-strip.html which are fairly flat down to 5Hz but for your 40 mics it'll set you back nearly £30k..... Given that your design uses an Arduino, I am thinking this is not the price budget you're aiming at....
    I think you might be better off designing your own 40-input mic preamp (or a single one 40 times or something in between) which work for your specific requirements. Speaking of which, if you could expand on those with more details (i.e. a little more than "As much as possible") and maybe give some background for your specific application then people might be able to help you more easily.
    Best Regards,
    Rachael
    0 DAB over 9 years ago
    Hi Noble,
    Can you supply some additional information, like some description of your application.
    At the frequencies you are wanting to measure, you will find it very hard to get a good result and keep your expenses low.
    I would suggest using an intermediary frequency, say 1K Hz and then measure your low frequency component using software.
    Otherwise you will have a lot of issues with signal resolution and extraction.
    I have been looking at a design to record the low frequencies of thunder, so I know what it is like to assess low frequency components.
    0 dougw over 9 years ago in reply to noblemaster
  • noblemaster
    0 noblemaster over 9 years ago in reply to DAB
    I am interested in measuring vibrations in 5Hz to 100Hz band and then analysis in MATLAB.. Mic model ICS40300. Signal is good with DC offset at 0.8V and max output at around 1.2V.
    I am using Arduino DUE, it has 12 bit ADC. I have few options in mind...
    1. https://www.sparkfun.com/products/9816
    What if I change its input cap at both stages from 1uF to 4.7uF?
    2. https://www.sparkfun.com/products/9868
    What if I replace its microphone with my desired model and change its input cap to 27uF?
    Which option is better from above two? or something else is required?
    Thanks.
  • noblemaster
    0 noblemaster over 9 years ago in reply to rachaelp
    Thanks.
  • noblemaster
    I am interested in measuring vibrations in 5Hz to 100Hz band and then analysis in MATLAB.. Mic model ICS40300. Signal is good with DC offset at 0.8V and max output at around 1.2V. I am using Arduino DUE, it has 12 bit ADC. I have few options in mind...
    Thanks.
  • WarrenW
    0 WarrenW over 9 years ago in reply to noblemaster
    Hi Noble.
    When calculating the low frequency cut off 3dB point you can do some simple maths of 1/(2 x Pi x Freq x Capacitor) to give the reactance and given the 10Kohm input on the 9816 module your reactance would need to be the same for a simple -3dB point (1/2 the amplitude). It's a simple voltage divider at that point.
    The 1uF gives about 33Kohm at 5hz.
    A 4.7uF would be approx. 6Kohm so should be able to amplify you 5 Hz with 'some' reduction in amplitude from the original waveform. DAB suggested superimposing a 1Khz 'carrier' and then filtering this which is a logical solution if you are going to MUX the inputs as the MUX rate will alter you LF waveforms.
    Now we take the MIC into account - whoa - it has a 3dB point of 6Hz! That will mean your levels will already be skewed. I hope you are not looking to analyse on amplitude and hope you are analysing freq only (i.e. presence of frequency not how loud).
    After about 10Hz things should flatten off.
    Hope this helps.
    Warren.
    0 michaelkellett over 9 years ago in reply to noblemaster
    To measure at up to 100Hz you need to sample each microphone at  500Hz or faster. For each microphone you will need a a buffer amplifier as shown on the Invensys data sheet and an anti-aliasing low pass filter which must allow the 100Hz signal thought but reduce the gain by, for example, 60 dB at 400 Hz. This requires 30dB per octave which is a fifth order filter. You could then sample at 800Hz and have no aliasing problems. To sample each of your 40 inputs at this rate is quite feasible but will need a sampling rate of 800 x 40 = 32000 samples per second at the processor. You might find it easier to sample faster and have a  more relaxed spec for the anti-alias filter.
    I don't know of  a commercial pre-amp that would do this - it will need to be custom made - I could do it for you (for money) or else I'm happy to advise you about how to set about it publicly on E14.
    I wouldn't use an Arduino for this - you'll need a custom board anyway so i would go for a processor with plenty of on chip RAM and number crunching.
    A board with 40 channels would be quite big - might be simpler to split it over a few boards.
