Arduino Forum Sensor
  • Answers 5 answers
  • Subscribers 416 subscribers
  • Views 1032 views
Sensor
arthur_hellemans
arthur_hellemans over 9 years ago
How can I connect a sharp sensor (GP2Y0A41SK0FGP2Y0A41SK0Fto an Arduino Wich cable do i need to buy
  • koudelad
    koudelad over 9 years ago +2 suggested
    Hello, if you don't find a cable, here are the components to make your own. The connector on the sensor is S3B-PH . Have a look into the datasheet . The housing is PHR-3 The contacts are SPH-002T-P0.5S…
  • koudelad
    koudelad over 9 years ago +1 suggested
    OK, you are saying you need to connect it to an Arduino. What connector do you expect to have on the other end?
  • koudelad
    0 koudelad over 9 years ago
    The connector on the sensor is S3B-PH . Have a look into the datasheet.
    The contacts are SPH-002T-P0.5S , SPH-002T-P0.5L or SPH-004T-P0.5S . You may also need the crimp tool WC-240
  • arthur_hellemans
    0 arthur_hellemans over 9 years ago in reply to koudelad
    We don't have enough time to make or own so we are searching for an assembled cable.
  • koudelad
  • arthur_hellemans
    just the three cables: ground, data, voltage-pin.
  • gadget.iom
    0 gadget.iom over 9 years ago in reply to arthur_hellemans
    Like this?
    5 Micro JST 2.0 PH-3-Pin Female WireS WITH MALE CONNECTOR PLUG QTY 5-26 AWG 300V | eBay
    0 jw0752 over 9 years ago
    Hi Arthur,
    Here is another good option if you are in the US and want it fast.
    https://www.sparkfun.com/products/8733
