Arduino Forum RF dongle and USB shield
  • Answers 2 answers
  • Subscribers 415 subscribers
  • Views 978 views
richardwbarnett
richardwbarnett over 8 years ago
Hello!
Thisis my first post on here and I'm am a bit of a novice so be gentle. I'm basically building I protect based around a neurosky mind wave EEG sensor. In the instructions I have seen you hack the dongle and take the Rx and TX directly from the dongle the the Arduino, this unfortunately means that the dongle can no longer be used in a PC.
I have bought a usb host shield to try and get round this but I'm struggling to see how I can collect the data I require as the RX and TX are no longer used. If anyone can help or even point me in the right direction I would really appreciate it!
Thanks in advance
Richard
  • gadget.iom
    gadget.iom over 8 years ago +2 suggested
    Have you cut the tracks yet? If your Arduino code just needs to listen to the dongle you could possibly just tap into the dongles TX line (Leaving RX untouched) so that the arduino could passively snoop…
  • beacon_dave
    beacon_dave over 8 years ago +1 suggested
    There appears to be some documentation provided on how to connect an Arduino to a MindWave mobile EEG sensor using a Sparkfun Bluetooth Modem which may be of interest: http://developer.neurosky.com/docs…
  • gadget.iom
    0 gadget.iom over 8 years ago
    If your Arduino code just needs to listen to the dongle you could possibly just tap into the dongles TX line (Leaving RX untouched) so that the arduino could passively snoop on the communication.
    This may work without cutting your USB signal traces and enable you to use the dongle for both applications simultaneously.
  • richardwbarnett
    0 richardwbarnett over 8 years ago in reply to gadget.iom
    I haven't cut the traces yet so I will try that! thank you very much!!
  • beacon_dave
    0 beacon_dave over 8 years ago
    http://developer.neurosky.com/docs/doku.php?id=mindwave_mobile_and_arduino
    SparkFun Bluetooth Modem - BlueSMiRF Silver
    https://www.sparkfun.com/products/12577
