Arduino Forum Effective usage of Arduino within a month??
  • Answers 3 answers
  • Subscribers 417 subscribers
  • Views 1279 views
fob
fob over 7 years ago
Good day guys,  what and what do I need to do (in terms of hardware and software) so that I can be able to confidently and effectively  use Arduino . I will appreciate your responses.
  • jomoenginer
    jomoenginer over 7 years ago +3 suggested
    It really depends on your experience, but Arduino has a pretty low technical entry point. You may start with a Arduino Stater Kit such as : https://store.arduino.cc/usa/arduino-starter-kit Then check out…
  • snidhi
    snidhi over 7 years ago +1 suggested
    I would suggest to find a project that you could use in your everyday life around house. Or something fun to do with the kids is also motivational. It can be a simple weather station to making your Christmas…
    dougw over 7 years ago +1 suggested
    There are many resources available for getting started with arduinos. Jeremy Blum did a series of tutorials among others. Jeremy Blum Arduino Tutorials It partly depends on where you are starting from…
  • snidhi
    0 snidhi over 7 years ago
    It can be a simple weather station to making your Christmas lights fancy.
    There are many day to day projects in element14. image
    Cheers
  • luislabmo
    0 luislabmo over 7 years ago
    Hi Olawale,
    Well, we will need more information on what you are looking for, learning?, you know how to use an arduino but are looking for a good project that keeps you entertained for a month?
    There are a lot of projects available at arduino.cc. If you are starting with Arduino I'd suggest to give a look at this Re: arduino for beginners
    Luis
    0 dougw over 7 years ago
    It partly depends on where you are starting from. What is your education and experience background?
  • jomoenginer
    0 jomoenginer over 7 years ago
    Then check out the Arduino Playground for basics on topics such as Board Setup and Configuration:
    NOTE: This will be going to Read-only at the end of December 2018
    http://playground.arduino.cc/
    Then the Arduino Tutorial site:
    https://www.arduino.cc/en/Tutorial/HomePage
    Outside of the cool projects listed on element14, have a peek at the Arduino Project Hub.
    https://create.arduino.cc/projecthub
    This Simon Monk book might be helpful if you prefer something in book format:
    https://www.amazon.com/Programming-Arduino-Getting-Started-Sketches/dp/1259641635/ref=dp_ob_title_bk
    Good luck
