Arduino Forum Arduino Programming debugging help
  • Replies 9 replies
  • Subscribers 419 subscribers
  • Views 1204 views
  • help
  • arduino_development_environment
GreenYamo
GreenYamo over 14 years ago
Hello, I am new to the world of Arduino, but loving finding out all about it and experimenting.
I would like some advice on debugging programs on the IDE, from what I can see there is no sort of step through function to trace program execution, and no way to track the contents of registers and setting of pins (eg, as on the PICAXE ide).
Is there something I am missing?
Thank you.
Steve
    Nope, you're not missing anything.
  • fustini
    0 fustini over 14 years ago
    Hi Steve,
    That's a good question and I think debugging is a downside to the Arduino environment.  I still save development time using it versus "raw" C or assembly, but debugging sometimes devolves into a rat's nest of print statements.
    Another e14 member actually asked this question last week:
    http://www.element14.com/community/message/49046#49046/l/re-debugging-atmega328
    There is a promising link in that thread which outlines an approach to step-by-step debugging.  I'm hoping to make time soon to try it out.
    Cheers,
    Drew
  • rew
    0 rew over 14 years ago in reply to fustini
    Hi Steve,
    I debug code on microcontrollers with print statments. Whenever I have a doubt about some variable, I will print it. Of course that often triggers me wanting to know the next (or previous) variable, so I'll have to recompile and download. But that's often very quick, so I don't mind too much.
    loop ()
    static int t;
    if (t >= 1000)
      t = 0;
      printf ("pins on portA are: %x\n", PINA);
    } else t++;
    delay_ms (1);
    (I don't remember what the delay function should be called under the arduino environment. I think printf just works like this. )
    Oh, and place an "serial.init (9600)'" in the initialization code.
    Then you can use the serial monitor to check for debug outptu.
  • R_Phoenix
    0 R_Phoenix over 14 years ago
    This might be a bit advanced for you, but the Arduino uses an ATMEL AVR chips. So you could program/Debug with AVR Studio Software,
    http://www.atmel.com/tools/ATMELAVRSTUDIO.aspx?Products=010%20Atmel%20AVR%208-%20and%2032-bit%20Microcontrollers
    However doing so will require a higher knowladge of C/C++ and you will need a programer to load and debug your programs. Basically, it will no longer be an Arduino.
  • fustini
    0 fustini over 14 years ago in reply to R_Phoenix
    Yeah, I'm keen to try this.  I have an AVR Dragon which supports debugWire.  There is a blog post I was looking at (from http://www.element14.com/community/message/49046#49008) that wrote the problem is that there is a cap on the reset line on the Arduino (which is what debugWire runs over).  The author removed it and then was able to debug ok.
  • R_Phoenix
    0 R_Phoenix over 14 years ago in reply to fustini
    Yah, not sure why that cap is there, help debounce when Arduino uploads maybe ??
    None of my variants have it and everything works fine.
  • fustini
    Oh, that's great to hear.  The blog author only wrote about the decimilia and the deumilinova, and I hadn't taken time to check out Uno yet.  Which variants do you have?
  • R_Phoenix
    It was my own desing, MEGA_Stick
    Although I no longer make it, Just a bit costly and there are better alternatives.
    However I am working on a second design, the MEGA Stick II which is smaller, only 1"x2.5", will have a ATMega 2560, no power regulator and no USB.
  • fustini
    Groovy, I'll look  forward to the MEGA Stick II.  Quite the footprint! image
