Arduino Forum How to control a load with Arduino
  • Subscribers 417 subscribers
  • Views 456 views
steve63
steve63 over 14 years ago
I would like to control through Arduino a load, ie a variable power switch connected to the mains (220-230V AC in my country). Which solution/sketch do you suggest to me?
Thanks in advance.
BR
    First you will need a 230VAC dimmer that will support the kind of loads you expect to deal with. One of these should suite you needs. But you'll need to find out what size potentiometer is on there and replace it with a digital one so the arduino can control it. With some searching you might be able to find a dimmer module that won't need any modification.
    This link may be helpful as well.
    http://www.epanorama.net/documents/lights/lightdimmer.html#1kw230v
  • steve63
    0 steve63 over 14 years ago in reply to e14 Contributor
    Michael,
    thank you so much for the useful links. I will go through them asap.
    Greetings
