Arduino Forum How to turn an led on and off via serial?
  • Subscribers 417 subscribers
  • Views 539 views
  • on
  • led
  • serial
  • off
jreeve17
jreeve17 over 13 years ago
Im trying to use this code to turn LED's on and  off via serial. The only problem is that i can't get them to go off on their own, the only way to do it is by resetting tha arduino. Does anyone know how to change the code to turn them off via serial?
Or is there a better code that someone knows to use?
void setup(){
  Serial.begin(9600);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
void loop (){
  if (Serial.available()) {
    char ser = Serial.read();
    switch (ser) {
      case '3':
        triggerPin(5);
        break;
      case '4':
        triggerPin(6);
        break;
void triggerPin(int pin){
  digitalWrite(pin, HIGH);
  • R_Phoenix
    0 R_Phoenix over 13 years ago
    If you turn it on by setting the pin HIGH, then you need to set the pin LOW to turn it off. If you want to use the same command to toggle the LED on and OFF try changing your triggerPin command to this,
         if(digitalRead(pin) == HIGH)
              digitalWrite(pin, LOW);
         else
              digitalWrite(pin,HIGH);
    if you manage to only get it working by serial here is a working sketch you could use for example.
    Just change it the way you want it to really do the jobs.
    boolean statePin5 = LOW; // To store the state of the pin 5
    boolean statePin6 = LOW; // same thing for pin 6
    void setup(){
      Serial.begin(9600);
      pinMode(5, OUTPUT);
      pinMode(6, OUTPUT);
    void loop (){
        switch (ser) {
          case '3':
            statePin5 = !statePin5; // change the state of the pin 5
            triggerPin(5, statePin5);
            break;
          case '4':
            statePin6 = !statePin6; // change the state of the pin 6
            triggerPin(6, statePin6);
            break;
          default:  // in case you have something different coming through serial
            digitalWrite(5, LOW); // back to low
            digitalWrite(6, LOW); // back to low
            statePin5 = !statePin5; // don't forget to change the state of each pin
            statePin6 = !statePin6; // also or you'll be missing a state in the sequence
            break;
    void triggerPin(int pin, int statePin){ // adding the pin state
      digitalWrite(pin, statePin); // enjoy !!!
    In case you really want to use the switch/case function don't forget to use the "default" case that is really powerfull to save a lot of trouble.
    Hope you'll find your way.
    Good luck.
