Arduino Forum Possibility of remote programming Arduino GSM
  • Subscribers 415 subscribers
  • Views 331 views
  • remote_programming_arduino
  • bootloader_arduino
Hello there!
I own a Mega 2560 + Ethernet Shield (Wiznet) + Arduino GSM (soon to be bought)
I've been searching around the web and I found Codebender, a web-based bootloader that makes it possible to upload a sketch through the web into Ethernet Shield (compatible with Wiznet). My goal is to do the same with GSM shield, to whenever I want, i would send a sketch over the web and it would be loaded and reprogram the Arduino.
Is this feasible? Is this already been done? Will i have to mess with bootloader of Arduino? I'm totally new to this area of programming microcontrollers, but i won't mind learning AVR programming, I just want to make sure I'm not wasting my time. Any guidelines and tutorials pointed out would be great! This or remotely uploading a sketch to SD Card and then flashing new code guidelines will also be welcome!
Thanks for any help you can give!
  • Workshopshed
    0 Workshopshed over 13 years ago
    Here's an example that reads the code from an SD Card
    http://www.roguerobotics.com/wikidocs/code/bootloader_using_ummc
    Here's another that performs a reset via code.
    http://www.toptal.com/c/how-i-made-a-fully-functional-arduino-weather-station-for-300
    So if you can download a file from the net store it on the card then reset the arduino that will load the new software in.
