Arduino Forum Need Help with Stepper Motor Coding
  • Subscribers 418 subscribers
  • Views 1216 views
  • stepper_motor
  • arduino_uno
Hello, I have a NEMA 17 stepper motor with an EasyDriver hooked up to an Arduino Uno. I have a -15 to 15V power supply with 12V powering the EasyDriver. Here is my code and then after the code I will ask my question.
int sensorPin = 0;
#include <Stepper.h>
const int stepsPerRevolution = 200;
int dirPin = 8;
int stepPin = 9;
Stepper myStepper(stepsPerRevolution, dirPin, stepPin);
void setup()
  myStepper.setSpeed(100);
  pinMode(dirPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  Serial.begin(9600);
void loop()
  int sensorValue = analogRead(sensorPin);
  float voltage = sensorValue * (5.0 / 1023.0);
  Serial.println(voltage);
  if (voltage > 2.60)
    myStepper.step(100);
    delay(1000);
  else if (voltage < 2.40)
    myStepper.step(-100);
    delay(1000);
I have it set at 200 steps per revolution with a speed of 100 RPM. What I want the motor to do is to read the voltage (which it does), turn 180 degrees depending on the voltage, wait one second, and then repeat. With the code I have, it takes three steps, pauses a second, and then repeats. It doesn't go 180 degrees like I want it to do. What can I do to in my code to make it do that?
  • colecago
    colecago over 13 years ago +2 verified
    I don't know if you are using library stepper.h correctly. I think the standard Arduino stepper library is for direct driving steppers. Thus Stepper myStepper(stepsPerRevolution, dirPin, stepPin); is meant…
  • colecago
    0 colecago over 13 years ago
    I think the standard Arduino stepper library is for direct driving steppers.  Thus Stepper myStepper(stepsPerRevolution, dirPin, stepPin); is meant to drive the coils, not controls for step and direction.
    Look at this link, it contains an example of something with more of a driver library
    http://www.maxuino.org/stepperdriver
    0 e14 Contributor over 13 years ago in reply to colecago
    Colecago, just wanted to let you know that you were indeed correct. I went to that link, downloaded that library, and everything is working great! I greatly appreciate your help. Thank you!
  • billabott
    0 billabott over 13 years ago
    Did you have to change any of your code to make it work "perfectly".  I think you should post the new sketch here.
    0 e14 Contributor over 13 years ago in reply to billabott
    This is my new sketch with more if statements than before:
    #include <StepperDriver.h>
    int sensorPin = 0;
    int dirPin = 8;
    int stepPin = 9;
    StepperDriver myStepper;
    void setup()
      myStepper.setStep(stepsPerRevolution, dirPin, stepPin);
      myStepper.setSpeed(50);
      myStepper.step(stepsPerRevolution*8);
      Serial.begin(9600);
    void loop()
      if (voltage >= 4.5)
        if (myStepper.update() == 1)
        delay(1000);
        myStepper.step(stepsPerRevolution);
      else if (voltage > 4.0 && voltage < 4.5)
        delay(1000);
        myStepper.step(stepsPerRevolution/2);
      else if (voltage > 3.5 && voltage <= 4.0)
        delay(1000);
        myStepper.step(stepsPerRevolution/4);
      else if (voltage > 3.0 && voltage <= 3.5)
        delay(1000);
        myStepper.step(25);
      else if (voltage > 2.6 && voltage <= 3.0)
        delay(1000);
        myStepper.step(1);
      else if (voltage > 2.0 && voltage <= 2.4)
        delay(1000);
        myStepper.step(-1);
      else if (voltage > 1.5 && voltage <= 2.0)
        delay(1000);
        myStepper.step(-25);
      else if (voltage > 1.0 && voltage <= 1.5)
        delay(1000);
        myStepper.step(-stepsPerRevolution/4);
      else if (voltage > 0.5 && voltage <= 1.0)
        delay(1000);
        myStepper.step(-stepsPerRevolution/2);
      else if (voltage >=0 && voltage <= 0.5)
        delay(1000);
        myStepper.step(-stepsPerRevolution);
  • billabott
    0 billabott over 13 years ago in reply to e14 Contributor
    On behalf of the Open Source Community, I thank you.
