Arduino Forum Help! need arduino sketch
  • Subscribers 417 subscribers
  • Views 524 views
Hi all
I'm new to this arduino forum.
I have a audio amp circuit that picks-up sound.
This amp is connected to a DTMF chip to
decode 0-9 and abcd on my key pad.
What i want to do is pick-up the sound of the key
that pressed on my keypad. then the DTMF chip
decode the pressed keys.then send the code
through my bluetooth module on my phone
then sees those numbers in an app call
BLUETERM. then save to phone.
Can someone write or help me with this Arduino sketch
where it will work right in my circuit.
All help is appreciated.
  • billabott
    0 billabott over 13 years ago
    If I were you, I might start here: http://forum.arduino.cc/index.php?topic=121540.0
    Happy Trails
    0 e14 Contributor over 13 years ago in reply to billabott
    Hi  billabott
    I already check this site.And found this will not help me.This person done it a different way.
    He wrote code for what he want to do in his controller.
    I need a direct DTMF sketch for a DTMF standalone chip like the HT9170 CM8870 chip.
    A sketch that is for these decoders.
  • billabott
    0 billabott over 13 years ago in reply to e14 Contributor
    The IC to be used is like this one: http://www.natalnet.br/~aroca/afron/mt8870.pdf , eh?
    The 4 pins, Q1 - Q4, are a half byte or nibble.  image
    Do you appreciate that when Delayed Steering (Output) pin goes high that is when the nibble needs to be captured?
    To do that the UNO will raise the TOE and read the nibble, store it, and bump the dataINarray pointer.  Lower the TOE
    Then watching for the Delayed Steering (Output) to go low would be needed to know the key has been released.    REPEAT.
    I don't seem to find any sketches on the web for that particular chip.  Sorry.
    UPDATE   Searching the www once again for "mt8870 arduino"
    I found something that may be of use to you!
    http://www.futurlec.com/Mini_MT8870.shtml has a board for $12.90 but no software offered.
    http://www.dossant.com/projects/products/dtmf-module/ has a cool llittle board that does this task.
    The .ino sketch is here: http://dossant.com/public_files/dtmf_module/proto2/dtmf_plug_in_loopback.ino
    or here: http://www.dossant.com/public_files/dtmf_module/dtmf_v400/dtmf_plug_in_loopback.ino
    There are some YouTube videos for MT8870 also.
    You may now also work over the  Arduino Forum using the search key "mt8870 ".
    Happy Trails.
  • billabott
    image 1. This sounds very much like a spy tool which may be illegal to use.  image  2. The word is "data". image  3. I don't think anyone here has time to write someone's custom sketch.  image
    If you insist on pursuing this goal then go follow http://lucidscience.com
    and don't miss their other SPY Gadgets on this page.
