Arduino Forum xbee question
  • Replies 12 replies
  • Subscribers 419 subscribers
  • Views 1210 views
xbee question
HI there guys,
My project is to connect one transmitting xbee to arduino
I also have a  receiving xbee (both series 1) I want that the receiving Xbee will show up a "hello world" that got sent from the transmitter XBee and display it on an LCD 16X2 screen
I'm quite baffled how am I supposed to do that? code wise,wiring wise...I've searched the web and couldn't find an answer maybe you could help me out plz?
thanks from advance chen (or grace its the same in Hebrew image )
  • fidelsalinas
    fidelsalinas over 13 years ago +1
    you'll need the following http://www.digi.com/support/kbase/kbasperesultdetl?id=2125 to update and program your xbees https://code.google.com/p/xbee-arduino/ the xbee arduino library http://arduino.cc…
    mcb1 over 13 years ago in reply to e14 Contributor +1
    Chen I might be wrong but you could try this. I suspect your lcd.print(Serial.read()); is treating what it reads as an integer, rather than a character, so when you print its simply a number rather than…
    0 mcb1 over 13 years ago in reply to e14 Contributor
    Chen
    You've found the helpful, and correct answers, as you've marked yourself.
    In theory they should be present in each respondants reply, but visible only to you.
    mark
    Chen
    I suspect your
    is treating what it reads as an integer, rather than a character, so when you print its simply a number rather than the ascii equivalent of the character j.
    try
      if(Serial.available( ) > 0 ) {
      char input = Serial.read();
          lcd.print(input);
    and see if it fixes it.
