Arduino Forum arduino not responding
  • Subscribers 417 subscribers
  • Views 635 views
tabarus12
tabarus12 over 12 years ago
My arduino apears to not respond, when I press the reset button the 13 pin light does not blink and when I try to upload a sketch shows the error "avrdude: stk500_getsync(): not in sync: resp=0x00", could this mean I have to upload the bootloader again or is this tipical of a chip malfunction on the arduino?, If anyone knows Id like to know please.
  • billabott
    0 billabott over 12 years ago
    http://forum.arduino.cc/index.php?topic=28223.0
  • tabarus12
    0 tabarus12 over 12 years ago in reply to billabott
    Not very helpfull, the discution shows 4 diferent problems and Ive tryed 3 of them and does not work, vesides the 13 pin light foes not blink like the topic sais it stays on all the time, even with the reset being pressed.
  • billabott
    0 billabott over 12 years ago in reply to tabarus12
    Well, then, I guess I don't know how you managed to mangle your 'Duino.
    Wait! You could carefully pry the ATMega328 out of its socket, straighten the pins and put it back it.  Why don't you try that?
  • tabarus12
    Well thanks for trying, Ill just dump the atmega and get another one to see if it works and if it does not Ill just have to modify all my projects to work with the RPI and dump 45 bucks to the trash, thanks anyways.
  • billabott
    I would like you to consider two low cost alternatives to RaspPi (not Open Souce Hardware, you know).
    1. The TI Launchpad with Energia.
    2  The Picaxe from Revolution Education.   See my personal blog about Beginning Picaxe.
    0 mcb1 over 12 years ago in reply to tabarus12
    If you posted just which version of Arduino you have it might help.
    There are UNO copies that use the FTDI style interface, and therefore will not communicate using the UNO board setting.
    There are others that don't include the newer bootloader.
    The message you are seeing is because it can't communicate.
    There is an example of how to check the USB to serial converter by removing the chip (assumming its socketed) and shorting D0 to D1, and you should see the characters you type come back to you.
    Perhaps some more info, and or a decent photo of it may render some other suggestions.
    Did you do something evil to it, as I've yet to see or hear of them suddenly not working.
    Was it working before?
    Does that USB port on other devices?
    Lots of questions.
