    • Avnet Boards Community
Arduino Forum Arduino resets when solenoid shuts off
  • Replies 54 replies
  • Answers 16 answers
  • Subscribers 396 subscribers
  • Views 8674 views
  • emi_protection
I have an arduino hooked to a 2 relay board. Each relay is opto-isolated. The arduino and board each have their own 5V power feed. The relays are switching 12V to controll a motor and a solenoid valve.
Sometimes when the solenoid turns off, the arduino resets. From what I've read, it's likely an EMI problem caused by the solenoid. If I disconnect the solenoid, I don't see the problem.
I've seen various suggestions about using a varistor or a diode, but I don't know which is better or what values to try. Any recommendations?
I'm assuming that the varistor or diode should be as close to the solenoid as possible, shorting the power and ground lines, is this correct?
Chris
  • c4m4ch0
    c4m4ch0 over 8 years ago in reply to maranatha +3 suggested
    Hello maranatha, you just need to connect the diode as it is in this image
    Former Member over 11 years ago in reply to michaelkellett +2 suggested
    I put an IN4004 Rectifier Diode across the terminals of the solenoid and that seems to have solved the problem. I also found this page pretty educational: http://en.wikipedia.org/wiki/Flyback_diode
  • maranatha
    maranatha over 8 years ago in reply to Former Member +1
    Hi Chris Do you happen to have the connection diagram? I am facing similar problem and it would be really helpful if you could share a connection diagram (basically how you connect the rectifier diode…
  • COMPACT
    0 COMPACT over 8 years ago in reply to maranatha
    It's good that it's working now.
    Hopefully it was just a loose connection.
  • maranatha
    0 maranatha over 8 years ago in reply to COMPACT
    I doubt that. It was happening for several times with different relays I tried with.
    But, lets see if this will continue to work.
    I will comeback and report this question as answered if the problem doesn't occur anymore.
    Otherwise, lets leave it open for discussion.
  • D_Hersey
    0 D_Hersey over 8 years ago
    You may also want to use some ferrite beads on your power feed
  • D_Hersey
    0 D_Hersey over 8 years ago in reply to michaelkellett
    Metalized polyester film is also used in arc suppression.
  • maranatha
    0 maranatha over 8 years ago in reply to D_Hersey
    Hi Don
    Where exactly to place the ferrite beads? For the arduino power feed or the raspberry pi power feed?
  • maranatha
    0 maranatha over 8 years ago in reply to maranatha
    Problem persists!
  • COMPACT
    Is there any reason for the RPi to be isolated from the Arduino?
  • D_Hersey
    0 D_Hersey over 8 years ago in reply to maranatha
    Why not both?  You should use a mix that is just a little slower than the signals you are trying to suppress
  • D_Hersey
    Make sure your supplies have big, fast decoupling capacitors
  • COMPACT
    0 COMPACT over 8 years ago in reply to D_Hersey
    Trying to find the root cause first.
