Arduino Forum Arduino uno Tempature fan control
  • Subscribers 416 subscribers
  • Views 588 views
  • fan
  • control
  • temperature
anaconda101
anaconda101 over 12 years ago
Hello i am fairly new at programing with a arduino and my first project was going to be controlling a 12 volt DC fan depending on what temperature it is. i am using a tmp36 to sense the temperature. i have a couple transistors and a relay that i tried using and i couldn't seem to get it to work. anyone have any suggestions? (if you think i need to buy anything just tell me.)
    0 dougw over 12 years ago
    Hi Ben,
    Here is a simple transistor circuit that should be able to drive your fan...
    If you list the part numbers you have I can modify the circuit to use them...
  • anaconda101
    0 anaconda101 over 12 years ago in reply to dougw
    my transistor part number is P2N2222AG
    temp. sensor is tmp36
    the relay is JZC-11F
    i see you are using a diode in this circuit i have one that is 1N4148
    thanks!
    0 dougw over 12 years ago in reply to anaconda101
    Hi Ben,
    This circuit uses your components...
    The resistor is needed to limit the current from the UNO output.
    The output of the TMP36 simply connects to an analog input of the UNO.
    Doug
