Arduino Forum Use of Acronyms and Initialisms in discussions
  • Replies 21 replies
  • Subscribers 422 subscribers
  • Views 3403 views
jw0752
jw0752 over 12 years ago
I am wondering if there is any merit in having a convention for the use of acronyms and initialisms in our discussions? I have been working in electronics for the last 50 plus years but I have not been able to keep up totally with the frontiers or diversity of this science. I have to admit that many times, as I read a description or explanation written by one of the more up-to-date members, I do not understand what they are talking about. The problem is not the ordinary words associated with electronics but rather the PID, TTH, PMBD, ETC. While being able to communicate with such initialisms adds a sense of in-group it is certain to frighten off some of the aspiring beginners as well as the old guys (me). I would propose that when using the Initialism for the first time in a discussion we put it down written out one time first. For example: (We must communicate effectively) WMCE. If "not" WMCE then we are wasting our time. Anyone know if there is a dictionary of electronic initialisms?
    jw0752 over 12 years ago +1
    The 722 people who viewed my post have inspired me to take one more step. I have compiled a little over 200 abbreviations, initialisms and acronyms that I will post here. This is just a beginning and I…
  • johnbeetem
    johnbeetem over 12 years ago in reply to e14 Contributor +1
    One of my favorites is PCMCIA: People Cannot Memorize Computer Industry Acronyms
    mcb1 over 12 years ago in reply to jw0752 +1
    Nice list. When I started at Airways the acronyms were an issue, so I asked if we had a list. 4 A4 pages later was the best they could do, and it wasn't complete. We had a boss once that insisted on using…
    0 jw0752 over 12 years ago
    The 722 people who viewed my post have inspired me to take one more step. I have compiled a little over 200 abbreviations, initialisms and acronyms that I will post here. This is just a beginning and I bet you can find several that should be on the list that I have forgotten or missed. If you think something should be on the list that is relevant to our conversations let me know. Also if I have incorrectly listed any of the below let me know. I will wait and try to produce an updated list in the near future.
    Thanks John
    ADCAnalog to Digital Convertor
    AAmpere
    AdissAverage Dissipation
    AFAudio Frequency
    AFEAnalog Front End
    AMAmplitude Modulation
    ANDLogical AND
    APCAutomatic Power Control
    ARMSAmpere Root Mean Square
    ATMAsychronous Transfer Mode
    bBase
    BJTBipolar Junction Transistor
    cCollector
    CACommon Anode
    CADComputer Aided Design
    CCCommon Cathode
    CCCSCurrent Controlled Current Switch
    CCDCharge Coupled Device
    CCLCopper Clad Layer
    CMOSComplementary Metal Oxide Semiconductor
    CPUCentral Processing Unit
    CTCenter Tapped
    dDrain
    DACDigital to Analog Converter
    DIMMDual Inline Memory Module
    DIPDual Inline Package
    DMMDigital Multimeter
    DMOSDiffused Metal Oxide Semiconductor
    DMXDemultiplexer
    DOFDegrees of Freedom
    DPDTDouble Pole Double Touch (Switch)
    DPDTCODouble Pole Double Touch Center Off (Switch)
    DPIDots Per Inch
    DPSTDouble Pole Single Touch (Switch)
    DRAMDynamic Random Access Memory
    DSPDigital Signal Processing
    DTLDiode Transistor Logic
    EPotential , Voltage, EMF
    eEmitter
    EADEmbedded Antenna Design
    EEPROMElectrically Erasable Programable Read Only Memory
    EMFElectroMotive Force
    EMPElectro Magnetic Pulse
    EOLEnd of Life
    ESREffective Serial Resistance
    EVElectron Volt
    FFarad (Capacitance)
    FETField Effect Transistor
    FIFOFirst In First Out
    FMFrequency Modulation
    FPAAField Programable Analog Array
    FPGAField Programable Gate Array
    FPLAField Programable Logic Array
    FSRForce Sensing Resistor
    FWFull Wave
    gGate
    GaAsGallium Arsenide
    GbGiga Bits
    GBGiga Bytes
    GFIGround Fault Interrupter
    GHzGiga Hertz
    GIGABillion
    GndGround
    GPIOGeneral Purpose Input Output
    GPSGlobal Positioning System
    GSMGlobal System for Mobile (Phones)
    HHenry (Inductance)
    HEDHall Effect Device
    hfeGain
    ***Human User Interface
    HVHigh Voltage
    HzHertz (Frequency)
    ICurrent
    I2CPhillips protocol Serial Bus
    ICIntegrated Circuit
    ICSPIn Circuit Serial Programming
    IDEIntegrated Development Environment
    IEEEInstitute of Electrical and Electronic Engineers
    IFIntermediate Frequency
    IOInput Output
    IotInternet of Things
    IPInternet Protocol
    IRInfra Red
    JFETJunction Field Effect Transistor
    KKilo (Thousand)
    KCathode
    KbKilo Bits
    KBKilo Bytes
    KVKilo Volt
    LANLocal Area Network
    LCDLiquid Crystal Display
    LEDLight Emitting Diode
    LEPLight Emitting Polymer
    LIFOLast In First Out
    LRCInductive Resistive Capacitive
    MMega (Million)
    mMilla (One Thousandth)
    mAMilli Amps
    MbMega Bits
    MBMega Bytes
    MCUMicro Controler Unit
    MDAMultiple Diode Array
    MhoConductance (1/Ohm)
    MIMOMultiple Input Multiple Output
    MOSMetal Oxide Semiconductor
    MOSFET Metal Oxide Semiconductor Field
    Effect Transistor
    MOVMetal Oxide Varistor
    MPUMicro Processor Unit
    MUXMultiplexer
    NANDLogical Not AND
    NANO10 to the -9th
    NCNormally Closed
    NCNo Connection or No Conductor
    nFNano Farad
    NONormally Open
    NORLogical Not OR
    NPNNegative Positive Negative
    OCPOver Current Protection
    OIOpto Isolator
    OPAMPOperational Amplifier
    ORLogical OR
    OVPOver Voltage Protection
    PCBPrinted Circuit Board
    PCMPower Control Module
    PEPiezo Electric
    pFPico Farad
    PFPower Factor
    PLLPhase Locked Loop
    PMPermanent Magnet
    PNPPositive Negative Positive
    PPPeak to Peak
    PPMParts Per Million
    PRIPrimary
    PROMProgramable Read Only Memory
    PUTProgramable Unijunction Transistor
    PWMPulse Width Modulation
    PZTPiezo Electric Transducer
    QTransistor
    QdissQuiescent Dissipation
    RResistance
    RAMRandom Access Memory
    RCResistive Capacitive
    RFRadio Frequency
    RFIRadio Frequency Interference
    RFIDRadio Frequency Identification
    RGBRed Green Blue
    RMSRoot Mean Square
    ROMRead Only Memory
    RSReset & Set
    RTDResistive Temperature Detector
    RTSRequest to Send
    RxReceive
    sSource
    SCLI2C Serial Clock Line
    SCRSilicon Controled Rectifier
    SDAI2C Serial Data Line
    SECSecondary
    SIMSubscriber Identification Module
    SIPSingle Inline Package
    SIPOSerial in Parrallel Out
    SISOSingle Input Single Output
    SMSurface Mount
    SMPSurface Mount Package
    SNRSignal to Noise Ratio
    SPDTSingle Pole Double Touch (Switch)
    SPDTCO Single Pole Double Touch Center OFF
    (Switch)
    SPISerial Periferal Interface
    SPSTSingle Pole Single Touch (Switch)
    SRAMStatic Random Access Memory
    TbTera Bits
    TBTera Bytes
    TCTime Constant
    TCPTransmission Control Protocol
    TdissTotal Dissipation
    TERATrillion
    TPTest Point
    TRIACTriode for Alternating Current
    TTLTransistor Transistor Logic
    TVSTransient Voltage Suppressor
    TxTransmit
    uMicro (One Millionth) actually should be μ
    UIntegrated Circuit
    uFMicro Farad
    uHMicro Henry
    URLUniform Resourse Locator
    USARTUniversal Sychronous Asynchronous Reciever Transmitter
    USBUniversal Serial Bus
    UVUltra Violet
    VVoltage
    VAVolt Ampere
    VACVolts Alternating Current
    VCCPlus Supply Voltage Collector, Positive rail
    VCCSVoltage Controlled Current Switch
    VddVoltage Drain to Drain
    VFOVariable Frequency Oscillator
    VggGate Voltage
    VINInput Voltage
    VOMVolt Ohm Meter
    VPPPeak to Peak Volts
    VREFReference Voltage
    VSS0 volts, Ground, negative rail
    WWatt
    WHWatt Hour
    XCrystal
    XReactance
    ZImpedance
    μMicro (One Millionth)
    ΩOhm (Resistnce)
    0 shabaz over 12 years ago
    Hi John,
    Wow, you're dedicated, to have compiled this list : )
    It's good that you bring this up.
    I too agree, it's always good practice to see the full expansion at least the first time, and then abbreviations can be acceptable in the rest of the article in question. However, I guess a few are generally accepted, such as V for volt since it is a unit. Hard to know what to do with those.
    There is a school of thought that any two-letter abbreviations are better always expanded throughout the article, rather than only expanding at the first mention of it. So, for example NO and NC should always be expanded to normally open and normally closed, and NO and NC should not appear in an article according to that principle. I don't always follow it 100%, but it's a good guideline and common-sense can be used.
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to shabaz
    I think the key factors are common sense and know your audience.  If I'm writing about FPGAs in the FPGA group, it's pretty silly and patronizing to expand it as Field-Programmable Gate Array, even the first time.  If it's for a general audience, then I should expand FPGA, though for most people the expanded form doesn't provide that much more information image  (Riiight... what's a gate array?)
    As for expanding two-letter initialisms each time: I'm not going to expand IP into Internet Protocol (or Intellectual Property) on each use and I don't think my readers want me to.  The whole point of initialisms is that humans are good at working with symbols and spelling them out unnecessarily gets tiresome IMO.  I love most Dashiell Hammett books, but I find The Glass Key really irritating because the main character is Ned Beaumont and every time DH mentions him it's always "Ned Beaumont".  Never "Ned", never "Beaumont", just Ned Beaumont, Ned Beaumont, Ned Beaumont over and over.
    0 e14 Contributor over 12 years ago in reply to shabaz
    JAFMA image
    The interesting part with acronyms is that you'll often find that two people with a differing history of companies they've worked for will have wildly different interpretations for the same TLA, or equally two totally different ones for the same thing. For example, two places I worked for used CND and NFF for essentially the same thing. I try to avoid using TLAs for reasons like this, I'm probably not totally successful though image
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to e14 Contributor
    One of my favorites is PCMCIA: People Cannot Memorize Computer Industry Acronyms image
    0 shabaz over 12 years ago in reply to e14 Contributor
    I was trying to guess CND/NFF and all I could think of was Campaign for Nuclear Disarmament, and then Nuclear Failure something as a guess : ) I needed to type it into google to find out what it really meant. The places I've worked, it would be a single-letter abbreviation, "U" (Unreproducible) if I've interpreted it correctly.
    I can see the point that sometimes it's not desirable to expand, e.g. FPGA in an FPGA group, and guidelines are made to be sometimes broken. Sometimes I've found an audience is really not aware of certain abbreviations or even buzzwords, although I thought they should have been aware (i.e. my bad judgement - and it gets harder with technology that is just a year or two old, it might not have permeated as quickly as I had thought). It's a hard balance. Others I've forgotten (like TRIAC - I know what it is, but not what the abbreviation is any longer) due to passage of time. But then, possibly people don't need to know what TRIAC stands for, since it has almost become a word (much like RADAR). I just checked what TRIAC stands for, and it could be an anachronism to today try to understand the expansion.
    So there are loads of subtleties to be factored in and always exceptions to guidelines.
    I also see extremely long abbreviations like EoMPLSoGRE and they are generally expanded the first time, although it may be done in sections (i.e. EoMPLS is expanded and discussed, and then the oGRE bit is expanded.
    0 jw0752 over 12 years ago in reply to shabaz
    Hi Shabaz  By the way congrats on your great interview. It is really interesting to learn more about the people behind the posts. I realized I was going over board with the single letter entries but once one is started it is hard to know where to draw the line so I threw them in. The one that push me over the edge and into action was the FPGA. I could not figure it out and had to do some research. John Beetem is correct, I still do not know what it is but at least now I can put the words to the letters. It sounds interesting and I will have to budget some time to learn a little more. Thanks again for your feedback.
    0 mcb1 over 12 years ago in reply to jw0752
    Nice list.
    We had a boss once that insisted on using them in his morning roundup talk, but never really explained them.
    In the end we started making some of our own up and he never did ask what they meant.
    mark
  • michaelwylie
    0 michaelwylie over 12 years ago
    I usually define the acronym the first time I use it in a post, then proceed to use the acronym afterwards. Just like you mentioned.
    Sounds like you've got it right, but perfect example is that you have yet another way to denote the same thing.
    When I used to work for a subcontract board manufacturer we used CND and could never work out why one of our customers sent some percentage of failed boards back to us labeled NFF. Later I changed job and started working for that same customer and discovered what NFF meant to them, and therefore also that whoever they had sorting out the returns didn't understand the acronym either!
