Arduino Forum How to Post Diagrams and Schematics?
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 1766 views
  • help
jw0752
jw0752 over 12 years ago
Whenever I  the need to add a diagram or schematic to my posts on the forum I have to hand draw the diagram, scan it into the computer as a  .jpg and then insert it into my post. I have noticed that there seem to be better ways to accomplish this. I would really appreciate some suggestions on how to draw and post diagrams and schematics. For example I have seen where the diagram appears as a clickable thumbnail. Also is there a better basic schematic CAD program to for use in this application. The program that I use to draw schematics works fine but the finished schematic is not transferable to a .doc or .txt format and can only be read by that specific program.
Thanks John
    jw0752 over 12 years ago in reply to vsluiter +1
    Hi Victor, Thanks for the good suggestions. I will check it out. I have a Digikey account so will look at theirs. By the way I really enjoyed your interview with Element-14 for their anniversary. It is…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    Allot of people use FRITZING Fritzing Fritzing as this allows you to draw diagrams for breadboards as well as produce a schematic like view for example this:
    The site seems to be having a problem with images right now so im simply linking in the URL to them
    http://www.element14.com/community/servlet/JiveServlet/downloadImage/38-16055-198231/1168-900/Lesson+4_bb.png
    and this
    http://www.element14.com/community/servlet/JiveServlet/downloadImage/38-16055-198232/Lesson+4_schem.png
    these are both from one of my Arduino Video Tutorials on this forum and created using FRITZING, it is free and great if you do allot of your hobby using breadboards, it will even create a PCB layout if you want to.
    and if those views dont work, here is the post with them in
    Fast Track to Arduino Programming - Lesson 4a, Ethernet input and response test console
    Hope this helps
    0 jw0752 over 12 years ago in reply to Robert Peter Oakes
    Thanks Peter, This is the kind of information that will be very helpful. I will start to familiarize myself with Fritzing.
  • vsluiter
    0 vsluiter over 12 years ago
    Although Fritzing is a great help for breadboarding it does not produce schematics as anyone in the electronics business is used to read. You can't do a simple 'opamp with transistor' schematic that's insightful at first sight, without knowing the pinout of the components. I used Circuitlab in the past when it was free. You can still use it as an editor, but have to pay for saved circuits. It produces schematics you can instantly share as an image like this:
    https://www.circuitlab.com/circuit/ge5sz3/screenshot/540x405/
    Digikey has a similar tool, and I think it is still free (haven't created an account to test yet), which is http://www.digikey.com/en/resources/scheme-it
    I just tried the free 'webtronics' tool, which is a bit clumsy and mostly suited for analog circuits, but completely free. You can save designs to your computer, and generate images:
    The amount of whitespace is quite annoying....
    Greetings,
    Victor
    0 jw0752 over 12 years ago in reply to vsluiter
    Hi Victor, Thanks for the good suggestions. I will check it out. I have a Digikey account so will look at theirs. By the way I really enjoyed your interview with Element-14 for their anniversary. It is nice to know the story behind the Engineer.
    there is one other of course which is EAGLE, available from ummmm Element 14 but also direct from here http://www.cadsoftusa.com/download-eagle/
    it is free for a limited sized board and double sided (If making boards is wat you end up doing. It is also very good for drawing out schematics and there is a whole load of tutorials, even on E14 community forums.
    I looked at the Fritzing and it was very Interessting. I made a simple board layout and then finished the schematic.  I hadn't given any thought to Eagle as my needs are so basic I would be hunting flys with a shotgun. The recent discussion on the forum about licensing also made me believe it was out of my league. If it is availabe for the hobbiest for 2 sided boards for free I will find time to take a look at it.
    Thanks Again John
    0 Robert Peter Oakes over 12 years ago in reply to jw0752
    for sure it is free for 2 sided and if it fits basically an arduino sized board which should cover most hobby uses at least in the beginning
  • vsluiter
    0 vsluiter over 12 years ago in reply to jw0752
    Thanks! I also liked the interview, it's a good transcription of what I've said.
    By the way, the reason why I looked at online tools is because with Eagle I find myself doing this iteration list that I found on this  (very interesting) discussion(Embedding a schematic editor - Electrical Engineering Meta Stack Exchange):
    Quote: RocketMagnet @ Embedding a schematic editor - Electrical Engineering Meta Stack Exchange
    I think this is an excellent idea. I would certainly love to be able to edit schematics directly in the questions and answers. Maybe it's just me, but my workflow for adding a schematic to an answer goes something like this.
    1. Launch Altium - wait
    2. New schematic - wait
    3. Search through several libraries to find the components I want
    4. Draw schematic
    5. Carefully edit each component designator, otherwise Altium puts red error wiggles everywhere
    6. Screen cap
    7. Launch paint program - wait
    8. remove all the grey grid if I can be bothered (tedious)
    9. Crop image
    10. reduce colours to 256
    11. save as PNG
    12. back to browser
    13. upload image
    14. realise I made a mistake in the schematic
    15. delete the image from the answer
    16. back to Altium
    17. Goto step 4
    I sometimes find myself going round this loop several times at the expense of about half an hour.
    I think that certain people are objecting to an in-browser because it's something they don't yet have. I expect that if we already had one, and clabacchio suggested getting rid of it, then those same people would be up in arms, explaining in detail why this was a bad idea.
    There was an updated discussion with more alternatives here: Simple online tool to draw circuit diagram / schematics? - Electrical Engineering Meta Stack Exchange
    Also, Eagle has a huge part library, which makes drafting schematics sometimes more cumbersome than needed.
    found these limitations for Version 7 (jst released), it is freeware given these limitations which for most of use is no limitation at all
    Limitations
    The following limitations apply to the EAGLE Light Edition in general:
    • The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
    • Only two signal layers can be used (Top and Bottom).
    • The schematic editor can only create one sheet.
    that's the ONLY limitations compared to the PRO version that is paid for
    0 Robert Peter Oakes over 12 years ago in reply to vsluiter
    Available from here http://www.cadsoftusa.com/download-eagle/freeware/
    Regards
    Peter
