Arduino Forum Arduino A-Star Programing
  • Replies 18 replies
  • Answers 2 answers
  • Subscribers 418 subscribers
  • Views 2849 views
analogue into an arduino a-star controlling a robo claw controller in encoder mode hooked up exactly like in page 48 in the orion manual
imageroboclaw_user_manual.pdf
    0 e14 Contributor over 12 years ago in reply to nschreiber0813
    do I write this to the roboclaw or to the a-star or both?
  • nschreiber0813
    0 nschreiber0813 over 12 years ago in reply to e14 Contributor
    I am pretty sure you send it to the robo claw but what is the difference?
  • nschreiber0813
    Dear: Allan
    It is neither this code is supposed to work with arduino uno. But you could probably make it compatible with the board and in that case I wish you good luck!!!
    Thank you I will try to make it work.
    Allan Manuel
  • nschreiber0813
    Make sure you mark the answers you found helpful as helpful and also make sure you mark the correct answer as correct. Thank you.image
    hi i have bssn trying to teach the arduino language and im not shure  but the last sketch you sent me does it have provisions for anlog input?
    i have been trying to teach myself sory for the type O in the previous message.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    Not sure how good your programming skills are but  have an initial set of intermediate programming videos on E14, I will be adding more over time but as your asking about reading analog values, there is one that does that, the rest teach how to use ethernet, read from the serial port and also how to code a command interpreter based on data on the serial or Ethernet or both
    Fast Track to Arduino Programming
    Hope it provides some insite
    Regards
    peter
